--- title: "Report - Page Object" description: "Each report may consist of multiple pages. The Page component may be selected by clicking on a Page item in the Project Browser." --- # Report - Page Object > Each report may consist of multiple pages. The Page component may be selected by clicking on a Page item in the Project Browser. ![" "](poInitial.png) ![" "](poProjectBrowser.png) ## Menu Bar Items Pages are added and removed from the the menu bar at the top of the browser. ![" "](poMenuBar.png) |Menu Item|Description| |---|---| |Add Page|Adds a new page to the report after the currently selected page.| |Add Page Previous|Adds a new page to the report prior to the currently selected page. A cover page may easily be added to a pre existing report by using Add Page Previous.| |Remove Page|Deletes the page that is currently visible in the main workspace.| ## Properties ![" "](poProps.png) |Property|Description| |---|---| |Fill|If true, the shape will fill its space with color.| |Fill Color|If fill is selected, the color that will fill the shape. |Opacity|How opaque the fill color is, between 0 and 1.| |Stroke Style|What style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to [Stroke and Fill Properties](ignition-modules\reporting\report-design\stroke-and-fill-properties-for-reports\stroke-and-fill-properties-for-reports.md).| |Stroke|[Details for the chosen stroke](ignition-modules\reporting\report-design\stroke-and-fill-properties-for-reports\stroke-and-fill-properties-for-reports.md). Each Stroke has its own properties depending on the Stroke Style chosen.| |Height|Height of this shape in pixels| |URL| A link to attach to this reporting component. Will be a clickable hyperlink if the report is exported as a PDF. You can use the values below to link to internal pages.**Page:Next** - Navigates to the next page.**Page:Back** - Navigates to the previous page.**Page:Number** - Replace "Number" with a numeral. Navigates to the specified page.| |Width|Width of this shape in pixels.| |Hidden| Allows the entire page to be excluded from the report. If true, the page will not be included in the report, and the page will display a Hidden warning in the Design tab and (Hidden) text following the page name in the Project Browser. Although this is a static boolean parameter value by default, it can become dynamic by selecting the property and right-clicking to choose the **Use dynamic data key** option. Alternatively, you can drag and drop a data key onto the property from the Key Browser. |
