Version: 8.3
Report - Images
The Image component lets you embed images into reports. Images can be dragged from a local computer, shared drive, webpage, or the Image Management Tool as files onto reports. They can also be pulled as binary data from a data source. If no Key is associated with the image component, the dropped image will be used. If the Key does not link to a valid image, no image will be shown. The image displayed in the Report Designer is a placeholder. It will be replaced with the image associated with the image's Key when the report is generated or previewed.
In the image component's Property Inspector, you can drag a parameter or a data source column from the Key Browser into the Key field. The Data Key can resolve to a byte array, such as an image retrieved from a database, or a URL that points to an image on the web, or an image file on a disk. Remember that reports are generated on the Gateway, so the image source needs to be accessible from the Gateway computer.
Keychain Expressions can not be used in the data key, but the Key can be a parameter or data source that dynamically constructs a path to an image. This allows you to easily change images in reports without changing the image component.
Report Design Component Palette Icon:
Properties​
PropertyDescription
FillIf true, the shape will fill its space with color.
Fill SelectedIf fill is selected, the color that will fill the shape.
OpacityHow opaque the fill color is, between 0 and 1.
Stroke StyleWhat style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to Stroke and Fill Properties.
StrokeDetails for the chosen stroke. Each Stroke has its own properties depending on the Stroke Style chosen.
Grow to FitIf true, rescale the original image to fit the shape.
KeyData Key for this image.
PaddingPadding between the image and the shape's bounds.
Page IndexFor multi-page images, sets the page index to use.
Preserve Aspect RatioIf true, preserve the aspect ratio when resizing the image.
RadiusThe amount to radius the corners of this shape.
RollNumber of degrees this shape is rotated clockwise.
Scale XAmount to scale the width of this shape. 1 is scale to 100%.
Scale YAmount to scale the height of this shape. 1 is scale to 100%.
URLA link to attach to this reporting component. Will be a clickable hyperlink if the report is exported as a PDF. You can use the values below to link to internal pages.
  • Page:Next - Navigates to the next page.
  • Page:Back - Navigates to the previous page.
  • Page:Number - Replace "Number" with a numeral. Navigates to the specified page.
VisibleIf true, the shape will be visible.
WidthWidth of this shape in pixels.
HeightHeight of this shape in pixels.
XHorizontal distance in pixels between the left edge of this shape and the left edge of the page.
YVertical distance in pixels between the top edge of this shape and the top edge of the page.
Example​
PropertyValue
KeyImage Path
The image in this report was created using a Parameter that resolved to a URL.
