--- title: "Report Component - Radar Chart" description: "A Radar Chart allows you to quickly see values in comparison to related items or groups." --- # Report Component - Radar Chart > A Radar Chart allows you to quickly see values in comparison to related items or groups. A Radar Chart allows you to quickly see values in comparison to related items or groups. Each value is plotted on a separate axis with a line drawn between the different values. This creates a shape that changes as the values change. An important property for the Radar Chart is **Extract Order**, which dictates whether to use an specified **Variable** or **Series** Key. ![](radar-chart.png) Report Design Component Palette Icon: ![](radar-chart-icon.png) ## Properties ### Property Inspector - Configure Tab ![](configure-tab.png) |Property|Description| |---|---| |Data Key|Unique identifier or placeholder to the data source that will populate the chart.| |Extract Order|Specifies if the row or column should be used for the chart.| |Series Key|Key for the series, visible only when the Extract Order is set to Row. | |Variable Key|Key for the variables, visible only when the Extract Order is set to Column.| |Series/Variable Colors |Adds a color to the chart for the corresponding data category.| |Scripting Enabled| Enables the script for this component to run.| |Edit Script ![](edit.png) | Allows the chart to be modified before the report is rendered.| ### Property Inspector - Properties Tab ![](properties-tab.png) |Property|Description| |---|---| |Data Key|Data key of the dataset that drives the Radar Chart.| |Extract Order|Specifies if the row or column should be used for the chart.| |Series Key|Key for the series, relevant only when the Extract Order is set to Row. | |Variable Key|Key for the variables, relevant only when the Extract Order is set to Column.| |Axis Color| Color for the axis lines.| |Axis Label Gap| Gap between axis and labels.| |Label Font|Font used for this chart's labels.| |Label Color| Color for the labels.| |Start Angle| Start angle of the Radar Chart in degrees.| |Rotation| Rotation direction of the spokes of the radar chart, clockwise or counter clockwise.| |Show Legend|If true, show the chart's legend.| |Legend Font|Font used for this chart's legend.| |Opacity|How opaque the fill color is, between 0 and 1.| |Stroke Style|What style of stroke or border to use: Hidden, Shape Outline, Border, or Double. To learn more about stroke styles, refer to [Stroke and Fill Properties](ignition-modules\reporting\report-design\stroke-and-fill-properties-for-reports\stroke-and-fill-properties-for-reports.md).| |Stroke|[Details for the chosen stroke](ignition-modules\reporting\report-design\stroke-and-fill-properties-for-reports\stroke-and-fill-properties-for-reports.md). Each Stroke has its own properties depending on the Stroke Style chosen.| |Roll|Number of degrees this shape is rotated clockwise.| |Scale X|Amount to scale the width of this shape. 1 is scale to 100%.| |Scale Y|Amount to scale the height of this shape. 1 is scale to 100%.| |URL| A link to attach to this reporting component. Will be a clickable hyperlink if the report is exported as a PDF. You can use the values below to link to internal pages.**Page:Next** - Navigates to the next page.**Page:Back** - Navigates to the previous page.**Page:Number** - Replace "Number" with a numeral. Navigates to the specified page.| |Visible|If true, the shape will be visible.| |Width|Width of this shape in pixels.| |Height|Height of this shape in pixels.| |X|Horizontal distance in pixels between the left edge of this shape and the left edge of the page.| |Y|Vertical distance in pixels between the top edge of this shape and the top edge of the page.| | Use Raster | If true, the component is displayed as a raster image. If false, the component is displayed as a vector. | ## Example ![](radar-chart-example.png) ```python title="Radar Chart Sample CSV Data" Name, Taste, Freshness, Price Banana, 8, 4, 4 Apple, 6, 9, 7 Pear, 9, 6, 6 ``` ![](example-props.png) |Property| Value| |--|--| |Extract Order| Row| |Series Key| Name| |Series Colors| #FFD800, #FF0000, #00AC00|
