Version: 8.3
Perspective - Motor
Component Palette Icon:
An animated component that looks like a motor. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
Properties​
NameDescriptionProperty Type
appearanceOptions for the appearance of the component. Options are auto, p&id, mimic, and simple. If set to auto, the value is taken from the Perspective Session Property symbols.autoAppearance.
value: string
animationSpeedThe speed of the animation as a percent. Set to "0" to turn off animation. If set to auto, the setting is taken from the Perspective Session Property symbols.autoAnimationSpeed.value: numeric
stateState of the animation. Built-in options are default, running, stopped, or faulted. Default is default.
Built-in states and new states can be configured and applied on the Project Properties > Symbols page.
value: string
orientationOrientation of the component. Options are top, bottom, left, or right. Default is right.color
labelLabel settings for the component.
  • text: Text for the label. Value is string.
  • location: Label position relative to the motor: top, bottom, left, right, or hidden. Default is bottom. Value is string.
  • justify: Label text justification: left, center, right, or auto. Default is center. Value is string.
  • style: Modify label text style using the style properties. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class
object
valueValue settings for the component.
  • text: Value to display as text. Value is string.
  • location: Value position relative to the motor: top, bottom, left, right, or hidden. Default is bottom. Value is string.
  • justify: Value text justification: left, center, right, or auto. Default is center. Value is string.
  • style: Sets a style for the value Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class
object
styleSets a style for this cylindrical tank. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. The Pump has two pre-configured variants.object
Component Events​
Example​
PropertyValue
props.orientationleft
props.label.textMotor 15
props.label.style.color#0000D9
props.label.style.fontWeightbold
props.label.style.fontFamilyNoto Sans
props.value.style.color#D97700
props.value.style.fontWeightbold
props.value.style.fontFamilyNoto Sans
props.style.fill#D97700
