Perspective - Link
Component Palette Icon:
Description
The Link component allows users to create a hyperlink that points to a destination such as a page, view, resource, or mount path that they can quickly navigate to. Links are easily identifiable because they typically have a different color font then the rest of the content, and an underscore when you hover over them. To configure a link, enter the URL for the destination, and the name of the link in the 'text' property.
Properties
| url | A URL, URL fragment, or a Page URL given to a Page. If the target is a Page, its Page URL can be found in the Page Configuration settings of the project. See Page URLs. | value: string |
| text | Text to display in the link. | value: string |
| target | Specifies where to display the linked URL. Options are:
Otherwise, supports standard w3c values for anchor link target attributes. | value: string |
| style | Sets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
Component Events
