--- title: "Perspective - Toggle Switch" description: "The Toggle Switch represents a bit: on (selected) or off (not selected)." --- # Perspective - Toggle Switch > The Toggle Switch represents a bit: on (selected) or off (not selected). ![](img1.png) **Component Palette Icon**: ![](img2.png) ## Description The Toggle Switch represents a bit: on (selected) or off (not selected). By default, when the switch is selected the color is blue. It is gray when it is not selected. Logically, this component is very similar to the Checkbox component. The Toggle Switch component has three pre-configured [variants](../../../../../ignition-modules/perspective/working-with-perspective-components/working-with-perspective-components.md): * No Text: Default layout with no text. * Text Right: Layout with text on the right of the Toggle Switch. * Text Left: Layout with text on the left of the Toggle Switch. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ---------- | -------------------- | ------------- | | selected | The selected state of the Toggle Switch. | value: boolean | | label | Settings for the label for the Toggle Switch.**text**: Text for the Toggle Switch. Text can also be entered directly by deep selecting the Toggle Switch component, which enables inline editing. Changes are immediately reflected in the text property field. Value is string.**position**: Text position relative to the Toggle Switch: right or left. Value is boolean.**style**: Modify text style using the style properties. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).| object | | color | Color settings for the Toggle Switch for each state it is in. Colors can be chosen from a color wheel, color palette, or entered as RGB or HSL values. See the [Color Selector](../../../../reference-pages/color-selector-reference/color-selector-reference.mdx) page for more information.**selected**: Color of the Toggle Switch when selected (on).**unselected**: Color of the Toggle Switch when unselected (off). **disabled**: Color of the Toggle Switch when disabled by the `enabled` property.**selected**: Color of the Toggle Switch when selected (on) and disabled.**unselected**: Color of the Toggle Switch when unselected (off) and disabled.| object | | enabled | Whether the user should be allowed to alter the Toggle Switch's selected state. Default is true.**Note:** If the component is disabled, scripts can still run on the component. For example, if you add a script action to the [onClick](https://docs.inductiveautomation.com/display/DOC81/Component+Events+and+Actions) event, the script will fire when the user clicks on the Toggle Switch. | value: boolean | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).| object | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![](img3.png) Image above shows both selected and deselected positions for the following properties. |Property|Value| |--|--| |props.label.text| Off / On| |props.label.position| left| |props.color.selected| #FF0000| |props.color.unselected |#8AFF8A|
