--- title: "Perspective - One-Shot Button" description: "The One-Shot Button is designed to send off a write request, and wait for a response, disabling the button until something resets the 'value' property on the component." --- # Perspective - One-Shot Button > The One-Shot Button is designed to send off a write request, and wait for a response, disabling the button until something resets the 'value' property on the component. ![](img1.png) **Component Palette Icon**: ![](img2.png) ## Description When the 'value' property and the 'setValue' property are equal, the component transitions to the writing state. Once 'value' and 'setValue' are no longer equal, the button returns to the ready state. The One-Shot Button has three pre-configured [variants](../../../../../ignition-modules/perspective/working-with-perspective-components/working-with-perspective-components.md): * Primary - Default design of the button. * Secondary - A secondary design for the button. * Require Confirm - Default design of the button but requires confirmation from user before action is submitted. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ------------- | --------------- | ------------ | | value | The current value displayed on the component. Should be bound bi-directionally to a tag. Default is 0. | value:  numeric, boolean, string, or null.| | setValue | The value to set when the button is pushed. Default is 1. | value:  numeric, boolean, string, or null.| | primary | Toggle between the default primary and secondary button style. Default is true. | value: boolean | | enabled | Whether the user can interact with the One-Shot Button. If disabled, the component cannot be used. Default is true. | value: boolean | | readyState | Displays the readyState value on the component.**text**: The text of the button while its value is not being written. Value is string.**style**: Modify readyState style using the style properties. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).**icon**: The Icon is an image path used to augment the readyState of the component by placing an image next to it.**path**: Shorthand path to icon source, in format: library/IconName. The materials icon library is a the primary source for icons, see https://fonts.google.com/icons?selected=Material+Icons. Value is string.**color**: Color of the icon. Can also assign color in "fill" of the style property. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector](../../../../reference-pages/color-selector-reference/color-selector-reference.mdx).**style**: Modify the readyState style using the style properties. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).|object| | writingState | Displays the writingState value on the component.**text**: The text of the button while its value is being written. Value is string.**style**: Modify readyState style using the style properties. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).**icon**: The Icon is an image path used to augment the readyState of the component by placing an image next to it.**path**: Shorthand path to icon source, in format: library/IconName. The materials icon library is a the primary source for icons, see https://fonts.google.com/icons?selected=Material+Icons. Value is string.**color**: Color of the icon. Can also assign color in "fill" of the style property. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector](../../../../reference-pages/color-selector-reference/color-selector-reference.mdx).**style**: Modify the readyState style using the style properties. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).| object | | confirm | If enabled, a message that asks the user to approve the requested operation. If the user doesn't confirm, then the value property will not update. **Note:** When configuring a script on this component while confirm is enabled, it is generally recommend that the script is placed on the `onActionPerformed` component event, since that event will wait for user confirmation.  **enabled**: If true, a confirmation box will be shown. Default is false. Value is boolean.**text**: Message to show user if confirmation is enabled. Default is "Are you sure?". Value is string.| object | | style | Sets a style for this component. Full menu of [style options](https://docs.inductiveautomation.com/display/DOC81/Style+Reference) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](https://docs.inductiveautomation.com/display/DOC81/Style+Classes). | object | | disabledStyle | Sets a style for this component when it is **disabled**. Full menu of [style options](https://docs.inductiveautomation.com/display/DOC81/Style+Reference) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](https://docs.inductiveautomation.com/display/DOC81/Style+Classes). | object | :::note If you are using both the style and disabledStyle properties, keep in mind that CSS dictates that style classes will be rendered in alphabetical order. In other words, specific elements of a style class will be overwritten if a later style class modifies the same element. ::: ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![](img3.png) | Property | Value |Style Category| | ------------------------------------ | ------------------------------ |--| |props.readyState.text |Start Process| N/A| |props.readyState.icon.path |material/trending_flat| N/A| |props.readyState.icon.color |#008000 |N/A| |props.writingState.text |Starting| N/A| |props.writingState.style.backgroundColor| #8AFF8A |background|
