--- title: "Perspective - Form Scripting" --- # Perspective - Form Scripting > This page details the various scripting, component, and extension functions available for [Perspective's Form](perspective-form.md) component. Scripting allows you to customize form behavior, handle validation dynamically, and respond to user actions. ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all possible event types for Perspective components. Not all event types apply to every component. For more information on configuring events, see [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md). ### onChange This event triggers whenever a form's input value changes. #### Properties | **Property** | **Type** | **Description** | |--------------------|------------|---------------------------------------------------------------------------------| | event.inputKey | String | The unique key identifying the input that triggered the change. | | event.newValue | Object | The new value of the input after the change. | | event.oldValue | Object | The previous value of the input before the change occurred. | | event.index | Integer | The index of the input if multiple inputs share the same key, such as in a repeater or table. Optional. | ### onSuccess This event triggers when a form submission completes successfully. #### Properties | **Property** | **Type** | **Description** | |--------------|----------|--------------------------------------------------------| | event | Object | The success response object returned after submission. | See [Form Submission](ignition-modules\perspective\scripting-in-perspective\perspective-session-events-scripts.md#form-submission) for handling form data on submission. ### onError This event triggers when a form submission fails. #### Properties | **Property** | **Type** | **Description** | |--------------|------------|--------------------------------------------------------------| | event | Object | The error response object returned from the submission. | See [Form Submission](ignition-modules\perspective\scripting-in-perspective\perspective-session-events-scripts.md#form-submission) for handling errors. ### onCancelActionPerformed If configured, this component event fires when the Form's cancel action is clicked. #### Properties | **Property** | **Type** | **Description** | |--------------|------------|---------------| | event | Object | A JSON object containing all form input data to be cancelled. | ### onSubmitActionPerformed If configured, this component event fires when the Form's submit action is clicked. #### Properties | **Property** | **Type** | **Description** | |--------------|------------|---------------| | event | Object | A JSON object containing all form input data to be submitted. | ## Component Functions ### .setCustomValidity(message, inputKey, index) #### Description Sets a custom validation message for a specific input field in the form. #### Parameters | **Parameter** | **Type** | **Description** | |------------------|------------|----------------------------------------------------------------------| | message | String | The custom validation message to display for this input. | | inputKey | String | The unique key identifying the input field. | | index | Integer | The index of the input if multiple inputs share the same key. Optional.| #### Return None #### Example To set a custom validation message for an email input field: ```python self.getSibling("Form").setCustomValidity("Please provide a valid email address.", "email") ``` :::info This message will persist until the field is corrected or the form is reset. ::: ### .reset() #### Description Resets all form inputs to their default values. #### Parameters None #### Return None #### Example To reset the form inputs to their default state: ```python self.getSibling("Form").reset() ``` ### .submit(preventInvalid) #### Description Submits the form, triggering [onSuccess](#onsuccess) if successful or [onError](#onerror) if submission fails. #### Parameters | **Parameter** | **Type** | **Description** | |----------------------|------------|----------------------------------------------------------------------| | preventInvalid | Boolean | When true, prevents the form from submitting if it is invalid. Optional.| #### Return None #### Example To submit the form with validation check enabled: ```python self.getSibling("Form").submit(preventInvalid=True) ``` ## Extension Functions This component does not have any extension functions associated with it.
