Perspective - View Canvas
Component Palette Icon:
Description
The View Canvas component can display multiple Perspective views, each positioned on a coordinate based system. The component offers smooth transition animations when views are relocated. Familiarity with CSS is helpful in taking full advantage of the this component.
Properties
| instances | Array of views to display in the canvas.
| array |
| transitionSettings | Transition settings on each view. The properties affected by transition settings are top, left, bottom, right, and zIndex.
| value: numeric |
| enableTransitions | Determines whether transitions should play when transitions are defined. | value: boolean |
| defaultStyle | Sets a style for all views. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
| style | Sets a style for the canvas. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
Scripting
See the Perspective - View Canvas Scripting page for the full list of scripting functions available for this component.
