--- title: "Perspective - Thermometer" description: "The Thermometer component displays a temperature value depicted as a level in a mercury thermometer." --- # Perspective - Thermometer > The Thermometer component displays a temperature value depicted as a level in a mercury thermometer. ![](2020-05-14_11-45-24.png) **Component Palette Icon**: ![](2019-05-07_9-44-54.png) ## Description The Thermometer component displays a temperature value depicted as a level in a mercury thermometer. Temperature intervals can be defined with their own colors so that the mercury color changes based on the temperature range. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ---------------- | --------------- | ---------------------- | | thermometerColor | Color of the outline of the thermometer. Default is black. | color | | mercuryColor | Color of the mercury. See [Color Selector](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx). | color| | axisLabelColor | The color of the thermometer's y-axis label. Default is black. See [Color Selector](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx). | color | | strokeWidth | Width of the lines used to draw the thermometer in pixels. | value: numeric | | highBound | The high boundary value for the whole thermometer. | value: numeric| | lowBound | The lower boundary value for the whole thermometer. | value: numeric| | value | The value to display in the thermometer. The mercury level and value label will change to reflect this. | value: numeric| | unit | A string to describe the units for the current value label. Options are "F" for Fahrenheit or "C" for Celsius. | value: string dropdown | | valueFontcolor | The color of the current value. See [Color Selector](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx). | color | | valueFont | The font to use for the current value label. **fontSize**: Size of the font for the current value. Value is numeric. | object | | intervals | Defines the upper and lower temperature range for each interval. **color**: Color of the mercury in the thermometer. See [Color Selector](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx).**high**: High bound value for the interval. Value is numeric.**low**: Low bound value for the interval. Value is numeric. | object | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![](2019-02-19_13-53-32-thm-ex-m.png) |Property|Value| |--|--| |props.unit| F| |props.mercuryColor |#8AFF8A| |props.intervals.1.high |45| |props.intervals.0.color| #0000FF| |props.intervals.1.color| #CCCCFF| |props.intervals.2.color| #FF0000| |props.intervals.2.low| 85| |props.value| 90|
