--- title: "Perspective - Progress" description: "The Progress bar visually indicates the progress of a task." --- # Perspective - Progress > The Progress bar visually indicates the progress of a task. ![](2018-12-10_15-43-38prgssbar.png) **Component Palette Icon**: ![](2019-05-07_9-38-21.png) ## Description The Progress bar visually indicates the progress of a task. It is used to display any value that has an upper and lower bound. Custom settings are available for the track and the bar. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ------------ | ----- | ------------------ | | min | The minimum value of the progress indicator. If the value reaches the max, the progress indicator will be completely filled. Must be less than the max. Default is 0. | value: numeric | | max | The maximum value of the progress indicator. If the value reaches the max, the progress indicator will be completely filled. Must be greater than 0.0. Default is 100. | value: numeric | | value | The current value representing the current progress. Must be greater than 0.0 and less than the value set in max. Default is 50. | value: numeric| | mode | Determines if the component should show a determinate state, or an indeterminate loading state. When set to determinate, shows the progress of the value relative to the min and max properties. | value: string | | bar | Settings for the bar. Full property descriptions included [below](#bar-and-track-child-properties). | object | | track | Settings for the track. Full property descriptions included [below](#bar-and-track-child-properties).| object | | valueDisplay | Value display configuration. Renders and styles a value overlay above the progress bar. **enabled**: If true, will show the value display. Value is boolean.**format**: Format to apply to value, which is then used in the value display. Value is string.**justify**: Horizontal alignment of the displayed value. Value is string.**style**: Sets a style for the track. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ### bar and track Child Properties | Name | Description | Property Type | | ------------- | ----- | ------------- | | color | A convenience property for setting the base color. This can also be accomplished by using the `prop.bar.style` or `prop.track.style` to set the background color. | object | | style | Sets a style. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | determinate | Determinate configuration. **color**: A convenience property for setting the color when mode is determinate. This can also be accomplished by using the `prop.bar.determinate.style` or `prop.track.determinate.style` to set the background color.**style**: Sets a style for the bar when mode is determinate. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).|object| | indeterminate | Indeterminate configuration. **color**: A convenience property for setting the color when mode is indeterminate. This can also be accomplished by using the `prop.bar.indeterminate.style` or `prop.track.indeterminate.style` to set the background color.**style**: Sets a style for the bar when mode is indeterminate. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Examples ### Example 1 ![](2019-04-12_16-19-38.png) |Property|Value| |--|--| |max| 100| |value |80| ### Example 2 ![](2020-05-01_11-02-40.png) |Property|Value| |--|--| |max| 100| |value |56| |mode| determinate| |bar.color| #FFAC47| |track.color| #FFE8CC| |track.borderStyle |solid| |track.borderWidth |2| |track.borderBottomLeftRadius| 15| |track.borderBottomRightRadius| 15| |track.borderTopRightRadius |15| |track.borderTopLeftRadius| 15| |track.borderColor |#A45324| |valueDisplay.enabled| true| |valueDisplay.format |percent| |valueDisplay.justify| center| |valueDisplay.fontFamily |Merriweather| |valueDisplay.fontWeight |bold|
