Perspective - PDF Viewer
Component Palette Icon:
Description
The PDF Viewer component displays a PDF that's hosted on a web server by providing a URL to the source property. A simple approach is to create either a File Resource or Mounted Folder within Web Dev, and set the source on the component to the resource's endpoint.
Properties
| showPageNumber | If true, the current page number and page count will be shown at the bottom of the component. | value: boolean |
| source | Path to the .pdf file to be displayed. Expects a URL to a PDF hosted on a web server. | value: string |
| style | Sets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
| page | The current page being displayed. | value: numeric |
| pageCount | The number of pages the pdf contains. Read only. | value: numeric |
Scripting
See the Perspective - PDF Viewer Scripting page for the full list of scripting functions available for this component.
