Perspective - Markdown
Component Palette Icon:
Descriptionβ
The Markdown component allows users to format any type of text so it is publishable as plain text without looking like it's been marked up with tags or formatting instructions. The Markdown component provides is a lightweight formatting language which is easy to write and easy to read. Markdown's formatting syntax only addresses issues that can be conveyed in plain text. For any marked up content that is not covered by Markdown's syntax, you can use HTML. You can even change the color of text in the component with HTML tags using the source prop in the Property Editor as shown in Example 2.
To learn more about how to use Markdown component for publishing plain text, refer to the following articles: Markdown Basics and Markdown Node Types.
If you would like to manually add line breaks, the most direct approach would be to disable the escapeHTML property, and add your own paragraph and line break elements. Once disabled, you can add line breaks as seen below:
Value of source | Result |
| Because there isn't a line break between "four" and "five", they're on the same line. ![]() |
Propertiesβ
| source | Text annotated with markdown syntax to display. | value: string |
| sectionSpacing | Number of pixels of vertical space between each section or header. | value: numeric |
| style | Sets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
| markdown | Lightweight formatting language that is easy to write and easy to read.
| object |
Component Eventsβ
Examplesβ
Example 1β
| Property | Value |
| props.source | MARKDOWN source:Markdown basic syntax link.From https://www.markdownguide.org.Text formatting examples: |
Example 2β
You can add additional lines within a list by ending the previous line with two spaces. In the example below, the text on the third line is actually "Third ". You can then force spaces via HTML using .
* First
* Second
* Third
The line above ends with two spaces
* Fourth
Example 3β
The following code was used in the example below and pasted into the source property of the Markdown component.
<p style="color:#AC00AC;"><B> Adding Color to your Text in the <BR>Markdown component </p
