Perspective - LED Display
Component Palette Icon:
Description
The LED Display is a stylized numeric and/or alphanumeric label. You can choose between a 7 segment and 14 segment visualization style, and also between nine common number format patterns.
The LED Display component has two pre-configured variants for the 7 Segment and 14 Segment styles.
Properties
| value | Value to be displayed. | value: numeric |
| segmentFormat | Style of each character/digit and the number of segments that compose the character. There are two different visual styles: 7 segment and 14 segment. Default is 14 segment. | value: string |
| numberFormat | Format of display for numeric characters, including commas, decimal places, percent, etc. There are nine options available from a dropdown list. Default is #,##0.00. | value: string |
| backgroundColor | Background color of the LED display. Default is #161616. See Color Selector. | color |
| diodeOnColor | Color of LED segments when switched on. Default is #1EC963. See Color Selector. | color |
| diodeOffColor | Color of LED segments when switched off. Generally different from display background color to preserve analog look. See Color Selector. | color |
| locale | Localization code that determines rules for commas, decimals, etc. Default is en-US. | value: string |
| style | Sets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
Component Events
Example
Example 1
| Property | Value |
| props.value | 12.34 |
| props.segmentFormat | 7 segment |
| props.backgroundColor | #D5D5D5 |
| props.diodeOnColor | #0062FF |
| props.OffColor | #0062FF1A |
Example 2
| Property | Value | Style Category |
| props.value | 52,345.9 | N/A |
| props.numberFormat | #,##0.00 | N/A |
| props.backgroundColor | #000000 | N/A |
| props.diodeOnColor | #00FF00 | N/A |
| prop.diodeOffColor | #000000 | N/A |
| props.style.borderStyle | groove | border |
| props.style.padding | 2px | margin and padding |
