--- title: "Perspective - Label" description: "The Label component displays text and can be customized." --- # Perspective - Label > The Label component displays text and can be customized. ![](image2018-6-13_8-45-44.png) **Component Palette Icon**: ![](2019-05-07_9-26-11.png) ## Description The Label component displays text and can be customized with a full menu of [style options](appendix/reference-pages/style-reference.md) for the appearance of text, background, border, color, etc. You can use bindings to display additional information on the Label component. ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | --------------- | -------------- | -------------- | |text|Text to display. Text can also be entered directly to the label by deep selecting the component, which enables inline editing. Changes are immediately reflected in the text property field. |value: string| |alignVertical|Vertical alignment of the text within the component (top, center, or bottom), based on the dimensions of the component. Default is top.|value: string| |textStyle| Sets a style for the text within this label. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ### Example 1 ![](2019-02-19_9-53-20.png) | Property | Value | | ----------------------- | -------------------------------------------------------------------------------------- | |props.text |(Expression Binding)`"The time is : "+dateformat(now(),"h:mm a")`| |props.style.borderStyle |groove| |props.style.padding |12px| ### Example 2 ![](lore-ipsum-label-amet.png) | Property | Value | | ----------------------- | -------------------------------------------------------------------------------------- | |props.text| Lorem ipsum dolor sit amet, consectetur adipiscing elit.| |props.textStyle.overflow |hidden| |props.textStyle.whiteSpace |nowrap| |props.textStyle.textOverflow| ellipsis| |props.style.borderStyle| double|
