Perspective - Label
Component Palette Icon:
Description
The Label component displays text and can be customized with a full menu of style options for the appearance of text, background, border, color, etc. You can use bindings to display additional information on the Label component.
Properties
| text | Text to display. Text can also be entered directly to the label by deep selecting the component, which enables inline editing. Changes are immediately reflected in the text property field. | value: string |
| alignVertical | Vertical alignment of the text within the component (top, center, or bottom), based on the dimensions of the component. Default is top. | value: string |
| textStyle | Sets a style for the text within this label. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
| style | Sets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
Component Events
Example
Example 1
| Property | Value |
| props.text | (Expression Binding)"The time is : "+dateformat(now(),"h:mm a") |
| props.style.borderStyle | groove |
| props.style.padding | 12px |
Example 2
| Property | Value |
| props.text | Lorem ipsum dolor sit amet, consectetur adipiscing elit. |
| props.textStyle.overflow | hidden |
| props.textStyle.whiteSpace | nowrap |
| props.textStyle.textOverflow | ellipsis |
| props.style.borderStyle | double |
