Perspective - Icon
Component Palette Icon:
Descriptionβ
The Icon component provides access to a collection of Scalable Vector Graphic (SVG) images, chosen to be useful as icons in a Perspective session.
The materials icon library is a primary source for icons, see https://fonts.google.com/icons?selected=Material+Icons. You can also add your own custom repository of icons. For more information on icons, see Images and Icons in Perspective.
When attempting to change the color of an icon via style class, set the desired color using the Text category's Color property.
Propertiesβ
| path | Shorthand path to icon source, in format: library/IconName (e.g., material/3d_rotation). See Icons for more information about available icons. | value: string |
| color | Color of the icon. See Color Selector. | color |
| style | Use Style to customize the visual style of the component. The Style menu contains all the tools for modifying text, background, margins, and borders. You can also specify a style class. | object |
Component Eventsβ
Examplesβ
Example 1β
| Property | Value |
| props.color | #00AC00 |
Example 2β
| Property | Value |
| props.path | material/record_voice_over |
| props.color | #000088 |
| props.style.borderstyle | ridge |
| props.style.borderColor | #FFAC47 |
| props.style.borderWidth | 6px |
