--- title: "Perspective - Google Map" description: "The Google Map component provides a new interactive map option to the Map component." --- # Perspective - Google Map > The Google Map component provides a new interactive map option to the Map component. ![](image-2023-10-5_10-39-27.png) Component Palette Icon: ![](image-2023-10-5_10-42-7.png) ## Description The Google Map component provides a new interactive map option to the Map component. The Google Map component is based on the LeafletJS plugin to use Google maps basemaps and allows scriptable interactions and various layer configurations including traffic, polygons, markers, and overlays. :::caution A Google Map API Key is required to be entered in the new [googleMapsApiKey](ignition-modules/perspective/perspective-sessions/session-properties.md#session-properties-table) session prop to provide a functional map without a Development Mode watermark. This API key will be exposed on the web application, so it is recommended to add restrictions following Google's [API Security Best Practices](https://developers.google.com/maps/api-security-best-practices#restrict_apikey). ::: ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ----------------------- | ------------------------ | -------------- | | init | The map's initial state on load. **center**: Initial geographic center of the map.**lat**: Latitudinal coordinate. Default value is 38.660867. **lng**: Longitudinal coordinate. Default value is -121.159728.**zoom**: Initial map zoom level. Default is 13.| object | | backgroundColor | Color used for the background of the map when the tiles have not yet loaded as the user pans. | value: string | | clickableIcons | Allow map icons to be clickable. These icons are also known as points of interest (POI) and represent areas like parks, schools, and shops . Default is true. | value: boolean | | cursor | Cursor related configuration.**draggable**: The name or URL of the cursor to display when mousing over a draggable map. This property uses the CSS cursor attribute to change the icon. As with the CSS property, you must specify at least one fallback cursor that is not a URL. Value is string.**dragging**: The name or URL of the cursor to display when the map is being dragged. This property uses the CSS cursor attribute to change the icon. As with the CSS property, you must specify at least one fallback cursor that is not a URL. Value is string. | object | | controlSize | Size in pixels of the controls appearing on the map. | value: numeric | | disableDefaultUI | Enables/Disables all default UI buttons. May be overridden individually. Does not disable the keyboard controls, which are separately controlled by the **keyboardShortcuts** property. Does not disable gesture controls, which are separately controlled by the **gestureHandling** property. | value: boolean | | fullscreen | Fullscreen related configuration.**controls**: Enabled/Disabled state of the Fullscreen control. Default is enabled. Value is boolean.**controlPosition**: Control display position. Default is top_left. Value is string. | object | | gestureHandling | Controls how the map handles gestures. Options include cooperative, greedy, auto, and none. Default is set to auto. | value: string | | heading | The heading for aerial imagery in degrees measured clockwise from cardinal direction North. | value: numeric | | isFractionalZoomEnabled | Whether the map should allow fractional zoom levels. | value: boolean | | keyboardShortcuts | Allows the map to be controlled by the keyboard when set to true. | value: boolean | | layers | Map layers configuration. See the [Layers](#layers-properties) section below for more detail on the available map layers. | object | | mapID | The Map ID of the map. | value: string | | mapType | MapType related configuration.**id**:The initial Map mapTypeId. Value is string.**controls**: The initial enabled/disabled state of the map type control. Value is boolean.**controlPosition**: Control display position. Default is top_left. Value is string.**controlMapTypeIds**: IDs of map types to show in the control.**controlStyle**: Style of map type control to display. Value is string. | object | | restriction | Defines a boundary that restricts the area of the map accessible to users. When set, a user can only pan and zoom while the camera view stays inside the limits of the boundary.**bounds**: When set, a user can only pan and zoom inside the given bounds. Bounds can restrict both longitude and latitude, or can restrict latitude only. For latitude-only bounds, use west and east longitudes of -180 and 180, respectively. For example: north: northLat, south: southLat, west: -180, east: 180.**north**: Latitude for Northern boundary. Value is string.**east**: Longitude for the Eastern boundary. Value is string.**south**: Latitude for the Southern boundary. Value is string.**west**: Longitude for the Western boundary. Value is string. **strict**: Bounds can be made more restrictive by setting the strictBounds flag to true. This reduces how far a user can zoom out, ensuring that everything outside of the restricted bounds stays hidden. The default is false, meaning that a user can zoom out until the entire bounded area is in view, possibly including areas outside the bounded area. Value is boolean. | object | | rotate | Rotate related configuration. **controls**: Enabled/Disabled state of the Rotate control. Default is enabled. Value is boolean.**controlPosition**: Control display position. Default is top_left. Value is string.| object | | scale | Scale related configuration. **controls**: Enabled/Disabled state of the Scale control. Default is enabled. Value is boolean. | object | | tilt | Controls the automatic switching behavior for the angle of incidence of the map. The only allowed values are 0 and 45. | value: numeric | | zoom | Zoom related configuration. **controls**: Enabled/Disabled state of the Zoom control. Default is enabled. Value is boolean.**controlPosition**: Control display position. Default is top_left. Value is string.**max**: The maximum zoom level which will be displayed on the map. Value is numeric.**min**: The minimum zoom level which will be displayed on the map. Value is numeric. | object | | style | Sets a style for this component. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ## Layers Properties ### overlayView Renders instances of Perspective views within the active project. | Name | Description | Property Type | | --------------------- | ------------------| -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | Enable/disable rendering of the OverlayView layer. | value: boolean | | mapPaneName | Map pane in which to render the OverlayView. Options include floatPane, mapPane, markerLayer, overlayLayer, overlayMouseTarget. | value: string | | bounds | Sets the bounds of the overlay. Either of bounds or position are required. **corner1**: South-West corner of the overlayView. **lat**: Latitudinal coordinate. Value is numeric.**lng**: Longitude coordinate. Value is numeric.**corner2**: North-East corner of the overlayView.**lat**: Latitudinal coordinate. Value is numeric.**lng**: Longitude coordinate. Value is numeric.| object | | position | OverlayView position. Either of bounds or positions are required. | object | | views | OverlayView instance configuration. **path**: Path to the view instance. Value is string.**params**: Params to pass to the view instance.**properties**: Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.**style**: Sets a style for the selected view. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.| object | | transparentBackground | If enabled, disables the default background color. | value: boolean | | shadow | If enabled, apply a box shadow around the view. | value: boolean | | zIndex | The z-index of the layer. | value: numeric | | properties | Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers. | object | | style | Sets a style for this overlayView layer. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | ### groundOverlay Binds and scales an image to fit projected ground coordinates. | Name | Description | Property Type | | ---------- | ------- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | Enable/disable rendering of GroundOverlay layer. | value: boolean | | overlays | Overlay related configuration. **source**: The URL of the image to display. Value is string.**bounds**: Sets the bounds of the GroundOverlay.**corner1**: South-West corner of the GroundOverlay, set using `lat` and `lng` properties.**corner2**: North-East corner of the GroundOverlay, set using `lat` and `lng` properties.**properties**: Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.| object | | clickable | If true, the ground overlay can receive mouse events. | value: boolean | | opacity | The opacity of the overlay, expressed as a number between 0 and 1. Optional. | value: numeric | | properties | Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers. | object| ### marker A marker identifies a location on a map. By default, a marker uses a standard image. Markers can display custom images. | Name | Description | Property Type | | -------------- | -------------- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | Enable/disable rendering of the marker layer. | value: boolean | | visible | If true, the marker is visible. | value: boolean | | markers | Marker related configuration. **position**: Marker position configuration.**lat**: Latitudinal coordinate. Value is numeric.**lng**: Longitude coordinate. Value is numeric.**icon**: Marker icon configuration.**type**: The icon type used as to represent the marker. Options include default, image, and symbol. Value is string.**popup**: If enabled, configured popups can be made visible for this marker. Popups do not apply to clusters.**tooltip**: If enabled, configured tooltips can be made visible for this marker. Tooltips do not apply to clusters.**properties**: Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers. | object | | clusterMarkers | Enables marker clustering. | value: boolean | | animation | Starts an animation. Any ongoing animation will be cancelled. Passing in null will cause any animation to stop. Default options include none, bounce, and drop. | value: string | | clickable | If true, the marker receives mouse and touch events. | value: boolean | | crossOnDrag | If false, disables cross that appears beneath the marker when dragging. | value: boolean | | cursor | Mouse cursor to show on hover. | value: string | | draggable | If true, the marker can be dragged. | value: boolean | | icon| Marker icon configuration. **type**: Selects shape configuration. Options include default, image, and symbol. Value is string. | object | | label | Adds a label to the marker. | value: string | | opacity | The marker's opacity between 0.0 and 1.0. | value: numeric | | optimized | Optimization enhances performance by rendering many markers as a single static element. This is useful in cases where a large number of markers is required. | value: boolean | | popup | If enabled, popup configuration for this marker. Popups do not apply to clusters.**enabled**: Enable marker popup. Value is boolean.**visible**: If true, the popup is visible. Value is boolean.**content**: The popup content to display.**text**: Text to display. Value is numeric.**view**: A view to display as popup content. If configured, overrides the text property.**path**: Path of view to display. Value is string.**params**: Parameters for the view. If passing parameters into the embedded view, the names here must match the parameters on that view.**autoClose**: Set it to false if you want to override the default behavior of the popup closing when another popup is opened. Value is boolean.**width**: Width of the popup. Min and Max values allowed.**disableAutoPan**: Disable panning the map to make the popup fully visible when it opens. Value is boolean.**pixelOffset**: The offset, in pixels, of the tip of the popup from the x and y points on the map at whose geographical coordinates the popup is anchored.**arialLabel**: AriaLabel to assign to the popup. Value is string.**zIndex**: All popups are displayed on the map in order of their z-index, with higher values displaying in front of popups with lower values. By default, popups are displayed according to their latitude, with popups of lower latitudes appearing in front of popups at higher latitudes. Popups are always displayed in front of markers. Value is numeric.**style**: Sets a style for the popup. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.| object | | tooltip | If enabled, tooltips can be configured for this marker. Tooltips do not apply to clusters.**enabled**: Enable marker tooltip. Value is boolean.**content**: The tooltip content to display.**text**: Text to display. Value is numeric.**view**: A view to display as tooltip content. If configured, overrides the text property.**path**: Path of view to display. Value is string.**params**: Parameters for the view. If passing parameters into the embedded view, the names here must match the parameters on that view.**direction**: Direction where to open the tooltip. Possible values are right, left, top, bottom, center, and auto. Auto will dynamically switch between right and left according to the tooltip position on the map. Value is string.**pixelOffset**: The offset, in pixels, of the tooltip from the marker's position. For tooltips configured with auto direction, positive offsets move the tooltip away from the marker's position.**permanent**: If true, the tooltip will display permanently, instead of only on mouseover. Value is boolean. **style**: Sets a style for the tooltip. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.| object | | shape | Image map region definition used for drag/click. **type**: Selects shape configuration. Options include none, circle, poly, rec. Value is string. | object | | title | Rollover text. | value: string | | zIndex | The z-index of the layer. | value: numeric | | properties| Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.| object | ### circle An array of circle layers. | Name | Description | Property Type | | ---------- | ------- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | Enable/disable rendering of the circle layer. | value: boolean | | visible | If true, the circle is visible. | value: boolean | | circles | Sets the center of the circle. **center**: Circle center configuration.**lat**: Latitudinal coordinate. Value is numeric.**lng**: Longitude coordinate. Value is numeric.**fill**: Circle fill configuration. Default properties include enabled, color, and opacity.**stroke**: Stroke configuration. Default properties include enabled, color, opacity, position, and weight.**properties**: Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers. | object| | radius | Sets the radius of this circle in meters. | value: numeric | | clickable | Indicates whether this circle handles mouse events. | value: boolean | | draggable | If set to true, the user can drag this circle over the map. | value: boolean | | editable | If set to true, the user can edit this circle by dragging the control points shown at the center and around the circumference of the circle. | value: boolean | | fill | Circle fill configuration. Default properties include enabled, color, and opacity. | object | | stroke | Stroke configuration. Default properties include enabled, color, opacity, position, and weight. | object | | zIndex | The z-index compared to other polys. | value: string | | properties| Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.|object | ### polygon Allows the map to draw arbitrary shapes at specified coordinates. An array of polygon layers. | Name | Description | Property Type | | ---------- | ------ | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | Enable/disable rendering of the polygon layer. | value: boolean | | visible | If true, the polygon is visible. | value: boolean | | polygons | **points**: Sets the path for this polygon. The ordered sequence of coordinates that designates a closed loop. Unlike polylines, a polygon may consist of one or more paths. As a result, the paths property may specify one or more arrays of LatLng coordinates. Paths are closed automatically.**lat**: Latitudinal coordinate. Value is numeric.**lng**: Longitude coordinate. Value is numeric.**fill**: Polygon fill configuration. Default properties include enabled, color, and opacity.**stroke**: Stroke configuration. Default properties include enabled, color, opacity, position, and weight.**properties**: The z-index compared to other polys. Value is string.| object | | clickable | Indicates whether this polygon handles mouse events. | value: boolean | | draggable | If set to true, the user can drag this polygon over the map. | value: boolean | | editable | If set to true, the user can edit this polygon by dragging the control points shown at the center and around the circumference of the circle. | value: boolean | | fill | Polygon fill configuration. Default properties include enabled, color, and opacity. | object | | geodesic | When true, edges of the polygon are interpreted as geodesic and will follow the curvature of the Earth. When false, edges of the polygon are rendered as straight lines in screen space. Note that the shape of a geodesic polygon may appear to change when dragged, as the dimensions are maintained relative to the surface of the Earth. | value: boolean | | stroke | Stroke configuration. Default properties include enabled, color, opacity, position, and weight. | object | | zIndex | The z-index compared to other polys. | value: string | | properties | Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers. | object | ### polyline An array of polyline layers. | Name | Description | Property Type | | ---------- | ------- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | Enable/disable rendering of the polyline layer. | value: boolean | | visible | If true, the polyline is visible. | value: boolean | | polylines|**points**: Sets the path for this polyline. The ordered sequence of coordinates of the Polyline. This path may be specified using either a simple array of LatLngs, or an MVCArray of LatLngs. Note that if you pass a simple array, it will be converted to an MVCArray. Inserting or removing LatLngs in the MVCArray will automatically update the polyline on the map. **lat**: Latitudinal coordinate. Value is numeric.**lng**: Longitude coordinate. Value is numeric.**icons**: The icons to be rendered along the polyline. See the table below for related [child properties](perspective-google-map.md#polylinepolylinesicon-properties).**stroke**: Stroke configuration. Default properties include enabled, color, opacity, position, and weight. **properties**: Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers. | object | | clickable | Indicates whether this polyline handles mouse events.| value: boolean | | draggable | If set to true, the user can drag this polyline over the map. | value: boolean | | editable | If set to true, the user can edit this polyline by dragging the control points shown. | value: boolean | | geodesic | When true, edges of the polygon are interpreted as geodesic and will follow the curvature of the Earth. When false, edges of the polygone are rendered as straight lines in screen space. Note that the shape of a geodesic polygon may appear to change when dragged, as the dimensions are maintained relative to the surface of the Earth. | value: boolean | | stroke | Stroke configuration. Default properties include enabled, color, opacity, position, and weight. | object | | zIndex | The zIndex compared to other polys. | value: string | | properties| Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.| object | #### polyline.polylines.icon Properties | Name | Description | Property Type | | -------- | ----------------------- | -------------- | | path | The symbol's path, which is a built-in symbol path, or a custom path expressed using SVG path notation. | value: string | | anchor | The position of the symbol relative to the polyline. The coordinates of the symbol's path are translated left and up by the anchor's x and y coordinates respectively. | object | | fill | Icon fill configuration. Default properties include enabled, color, and opacity. | object | | rotation | The angle by which to rotate the symbol, expressed clockwise in degrees. A symbol in an IconSequence where fixedRotation is false is rotated relative to the angle of the edge on which it lies. | value: numeric | | scale | The amount by which the symbol is scaled in size. Defaults to the stroke weight of the polyline. After scaling, the symbol must lie inside a square 22 pixels in size centered at the symbol's anchor. | value: string | | stroke | Icon stroke configuration. Default properties include enabled, color, opacity, position, and weight. | object | ### rectangle An array of rectangle layers. | Name | Description | Property Type | | ---------- | -------- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | Enable/disable rendering of the rectangle layer. | value: boolean | | visible | If true, the rectangle is visible. | value: boolean | | rectangles | Sets rectangle configuration. **bounds**: Sets the bounds of the rectangle.**corner1**: South-West corner of the rectangle, set using `lat` and `lng` properties.**corner2**: North-East corner of the rectangle, set using `lat` and `lng` properties.**fill**: Rectangle fill configuration. Default properties include enabled, color, and opacity.**stroke**: Stroke configuration. Default properties include enabled, color, opacity, position, and weight.**properties**: Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.| object | | clickable | Indicates whether this rectangle handles mouse events. | value: boolean | | draggable | If set to true, the user can drag this rectangle over the map. | value: boolean | | editable | If set to true, the user can edit this rectangle by dragging the control points shown. | value: boolean | | fill | Rectangle fill configuration. Default properties include enabled, color, and opacity. | object | | stroke | Stroke configuration. Default properties include enabled, color, opacity, position, and weight. | object | | zIndex | The z-index compared to other polys. | value: string | | properties| Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers. | object | ### bicycling Shows bicycle route information. | Name | Description | Property Type | | ---------- | ----- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | If true, displays bike lanes and paths and demotes large roads. | value: boolean | | properties | Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.| object | ### traffic Shows traffic information. | Name | Description | Property Type | | ----------- | -------- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | If true, displays current road traffic. | value: boolean | | autoRefresh | Whether the traffic layer refreshes with updated information automatically. | value: boolean | | properties| Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers. | object| ### transit Shows transit information. | Name | Description | Property Type | | ---------- | --------- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | If true, enables layer that displays transit lines. | value: boolean | | properties | Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.| object| ### kml Keyhole Markup Language (KML) configuration to specify a set of geographic visualizations. | Name | Description | Property Type | | ------------------- | -------- | -------------- | | name | A unique name which is used to distinguish this element from others. This name is provided to any applicable interaction event handlers, such as click handlers. | value: string | | enabled | Enable/disable rendering of a KML layer. | value: boolean | | url | The URL of the KML document to display| object | | clickable | If true, the layer receives mouse events | value: boolean | | preserveViewport | If this option is set to true or if the map's center and zoom were never set, the input map is centered and zoomed to the bounding box of the contents of the layer. | value: boolean | | screenOverlays | Whether to render the screen overlays. | value: boolean | | suppressInfoWindows | Suppress the rendering of info windows when layer features are clicked. Default is null. | value: string | | zIndex | The z-index of the layer. Default is null. | value: numeric | | properties | Properties of this element. These are provided to any applicable interaction event handlers, such as click handlers.| object| ## Scripting See the [Perspective - Google Map Scripting](perspective-google-map-scripting.md) page for the full list of scripting functions available for this component. ## Example The example below incorporates multiple layers to display bike paths and mark a location at the center of an editable circle using layers. ![](image-2023-10-11_13-39-19.png) **Properties** * layers.marker.0: Default marker icon |Property|Value| |--|--| |markers.0.position.lat |38.660867 | |markers.0.position.lng|-121.159728 | | markers.0.icon.type|default | * layers.circle.0: Red circle layer centered at the marker icon location |Property|Value| |--|--| |circles.0.center.lat |38.660867 | |circles.0.center.lng |-121.159728 | |circles.0.fill |#FF0000 | |radius|300 | * layers.bicycling: Visible bicycle routes |Property|Value| |--|--| |enabled|true |
