--- title: "Perspective - Cylindrical Tank" description: "A component that looks like a 3D cylindrical tank with some liquid inside." --- # Perspective - Cylindrical Tank > A component that looks like a 3D cylindrical tank with some liquid inside. ![](2019-02-15_16-05-17.png) **Component Palette Icon**: ![](2019-05-07_9-16-28.png) ## Description This component looks like a 3D cylindrical tank with liquid inside. It can be configured so that the "liquid" rises and falls as the `value` property changes. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). ## Properties Most Properties have binding options. For more information on Bindings, see [Types of Bindings in Perspective](ignition-modules/perspective/working-with-perspective-components/bindings-in-perspective/bindings-in-perspective.md). This section only documents the Props Category of properties. The other Categories are described on the [Perspective Component Properties](ignition-modules/perspective/working-with-perspective-components/perspective-component-properties.md) page. | Name | Description | Property Type | | ------------------ | ---------------- | -------------- | | value | Numeric value of the tank's level. | value: numeric | | capacity | Total capacity of the tank. Default is 100. | value: numeric | | liquidColor | Color used to render the filled part of the tank. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector.](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx)| color | | tankColor | Color of the non-filled tank section. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See [Color Selector.](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx) | color | | liquidOpacity | The opacity of the liquid in the tank. 0 is fully transparent, 1 is fully opaque. Default is 0.5. | value: numeric | | liquidWarningColor | The warning color of the liquid in the tank. See [Color Selector.](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx) | color| | tankWarningColor | The tank warning color. See [Color Selector.](appendix/reference-pages/color-selector-reference/color-selector-reference.mdx) | color| | warningThreshold | The warning appearance will be used when value as a percentage of the capacity exceeds this value. Default is 100 | value: numeric | | strokeWidth | The stroke width, in pixels, for the outside of the tank. Default is 1. | value: numeric | | valueDisplay | Value display configuration. Renders and styles a value overlay in the tank. Click here to see [valueDisplay](perspective-cylindrical-tank.md#valuedisplay-properties) properties. | object | | style | Sets a style for this cylindrical tank. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md).| object | ### valueDisplay Properties | Name | Description | Property Type | | ------- | ------------ | -------------- | | enabled | Whether valueDisplay is shown. Default is true. | value: boolean | | style | Modify the valueDisplay style using the style properties. Full menu of [style options](appendix/reference-pages/style-reference.md) is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a [style class](ignition-modules/perspective/styles/style-classes/style-classes.md). | object | | format | Format to apply to value which is then used as the display value. Available options include: NoneIntegerPercentCurrency | value: string | | unit | Unit value to display on value overlay:**enabled**: If true, will show either a prefixed or postfixed unit. Value is boolean. **value**: Unit value to display. Value is string. **fix**: Direction in which to place the unit. Either as a prefix or a postfix. Value is string.   | object | ## Component Events The [Perspective Event Types Reference](appendix/reference-pages/perspective-event-types-reference.md) page describes all the possible component event types for Perspective components. Not all component events support each Perspective component. The [Component Events and Actions](ignition-modules/perspective/working-with-perspective-components/component-events-and-actions.md) page shows how to configure events and actions on a Perspective component. Component scripting is handled separately and can be accessed from the Component menubar or by right clicking on the component. ## Example ![](2019-08-27_9-53-08.png) |Property|Value| |--|--| |props.value| 85| |props.capacity |100| |props.warningThreshold|80|
