Perspective - Cylindrical Tank
Component Palette Icon:
Description
This component looks like a 3D cylindrical tank with liquid inside. It can be configured so that the "liquid" rises and falls as the value property changes. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class.
Properties
| value | Numeric value of the tank's level. | value: numeric |
| capacity | Total capacity of the tank. Default is 100. | value: numeric |
| liquidColor | Color used to render the filled part of the tank. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector. | color |
| tankColor | Color of the non-filled tank section. Can be chosen from color wheel, chosen from color palette, or entered as RGB or HSL value. See Color Selector. | color |
| liquidOpacity | The opacity of the liquid in the tank. 0 is fully transparent, 1 is fully opaque. Default is 0.5. | value: numeric |
| liquidWarningColor | The warning color of the liquid in the tank. See Color Selector. | color |
| tankWarningColor | The tank warning color. See Color Selector. | color |
| warningThreshold | The warning appearance will be used when value as a percentage of the capacity exceeds this value. Default is 100 | value: numeric |
| strokeWidth | The stroke width, in pixels, for the outside of the tank. Default is 1. | value: numeric |
| valueDisplay | Value display configuration. Renders and styles a value overlay in the tank. Click here to see valueDisplay properties. | object |
| style | Sets a style for this cylindrical tank. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
valueDisplay Properties
| enabled | Whether valueDisplay is shown. Default is true. | value: boolean |
| style | Modify the valueDisplay style using the style properties. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
| format | Format to apply to value which is then used as the display value. Available options include:
| value: string |
| unit | Unit value to display on value overlay:
| object |
Component Events
Example
| Property | Value |
| props.value | 85 |
| props.capacity | 100 |
| props.warningThreshold | 80 |
