Perspective - Barcode
Component Palette Icon:
Description
The Barcode component enables you to display text as a barcode. The component supports 105 different barcode types including Code 128, QR code, EAN-8, and ISBN.
The Barcode component has two pre-configured variants: Code 128 and QR Code.
Properties
| value | Value to be encoded as a barcode. | value: numeric |
| type | What barcode specification to use, currently there are 105 formats supported including Code 128, QR code, EAN-8, and ISBN. Click here to see the barcode specification options. | value: string |
| displayValue | If true, the barcode's value will be displayed as text. | value: boolean |
| valuePosition | If displayValue is true, this property determines where the value should be displayed. Options are top or bottom; default is bottom. | value: string |
| valueStyle | Sets a style for the display value for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
| errorStyle | Sets a style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
| style | Sets an overall style for this component. Full menu of style options is available for text, background, margin and padding, border, shape and miscellaneous. You can also specify a style class. | object |
Barcode Specification Options
| A-B | C | D | E-G |
| auspost azteccode azteccodecompact aztecrune bc412 | channelcode, codablockf, code11 code128 code16k code2of5 code32 code39 code39ext code49 code93 code93ext codeone coop2of5 | daft databarexpanded databarexpandedcomposite databarexpandedstacked databarexpandedstackedcomposite databarlimited databarlimitedcomposite databaromni databaromnicomposite databarstacked databarstackedcomposite databarstackedomni databarstackedomnicomposite databartruncated databaretruncstedcomposite datalogic2of5 datamatrix datamatrixrectangular datamatrixrectangularextension dotcode | ean13 ean13composite ean14 ean2 ean5 ean8 ean8composite flattermarken gs1-128 GS1-128 gs1-128composite gs1-cc gs1datamatrix gs1datamatrixrectangular gs1northamericancoupon gs1qrcode |
| H-J | K-P | Q-Z |
| hanxin hibcazteccode hibccodeablockf hibccode128 hibccode39 hibcdatamatrix hibcdatamatrixrectangular hibcmicropdf417 hibcpdf417 hibcqrcode iata2of5 identcode industrial2of5 interleaved2of5 isbn ismn issn itf14 japanpost | kix leitcode mailmark matrix2of5 maxicode micropdf417 microqrcode msi onecode pdf417 pdf417compact pharmacode pharmacode2 planet plessey posicode postnet pzn | qrcode rationalizedCodabar raw royalmail sscc18 symbol telepen telepennumeric ultracode upca upcacomposite upce upcecomposite |
Component Events
Examples
Example 1
| Property | Value |
| props.value | 014113910613 |
| props.type | upca |
| props.displayValue | true |
| props.valuePosition | bottom |
| props.valueStyle.fontFamily | Verdana |
| props.valueStyle.fontSize | 18px |
Example 2
| Property | Value |
| props.value | http://inductiveautomation.com |
| props.type | qrcode |
| props.valuePosition | top |
| props.valueStyle.color | #2747C7 |
| props.valueStyle.fontFamily | sans-serif |
| props.valueStyle.fontSize | 14px |
| props.valueStyle.fontWeight | bold |
| props.style.paddingTop | 12px |
| props.style.borderColor | D97700 |
