Perspective - Audio Scripting
This page details the various scripting, component, and extension functions available for Perspective's Audio component.
Component Eventsβ
onPlayβ
This event is fired when playback has begun.
eventβ
Object Path
- event
Type
- Null
Description
- An empty event object.
onPauseβ
This event is fired when playback has been paused.
eventβ
Object Path
- event
Type
- Null
Description
onErrorβ
This event is fired when there is an error attempting to play the media file.
This component event is designed to be used in tandem with a script action. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter.
event.errorMessageβ
Object Path
- event.errorMessage
Type
- String
Description
- Error message when attempting to play the media file.
onEndedβ
This event is fired when playback has ended due to reaching the end of the media.
eventβ
Object Path
- event
Type
- Null
Description
onLoadedβ
This event is fired when the first frame of the media has loaded.
eventβ
Object Path
- event
Type
- Null
Description
onRateChangedβ
This event is fired when the playback rate of the media has changed.
eventβ
Object Path
- event
Type
- Null
Description
Component Functionsβ
.play()β
Description
- Plays the media file, triggering the onPlay component event.
Parameters
- None
Return
- Nothing
.pause()β
Description
- Pauses the media file, triggering the onPause component event.
Parameters
- None
Return
- Nothing
.replay()β
Description
- Replays the media file from the beginning.
Parameters
- None
Return
- Nothing
Extension Functionsβ
