Version: 8.3 Beta 🚧
Perspective - Coordinate Container Scripting
This page details the various scripting, component, and extension functions available for Perspective's Coordinate Container component.
Component Events​
onPipeClicked​
This event will trigger when a pipe in this container is clicked.
note
This component event is designed to be used in tandem with a script runAction. Within the script action, special properties and methods are available on the event object, which is passed to the script action as a parameter.
event.event​
  • Object Path
    • event.event
  • Type
    • Dictionary
  • Description
    • The event object generated from the mouse click.
event.pipeIndex​
  • Object Path
    • event.pipeIndex
  • Type
    • Integer or float
  • Description
    • The array index of the pipe within props.pipes that was clicked.
event.pipeName​
  • Object Path
    • event.pipeName
  • Type
    • String
  • Description
    • The name of the pipe that was clicked.
Component Functions​
.getChildren()​
  • Description
    • Returns an ArrayList, which contains references to all components inside of the container.
  • Parameters
    • None
  • Return
    • Array List - An ArrayList of components in the container. The resulting ArrayList can be iterated over via a for-loop.
Extension Functions​
