--- title: "Leased Tag Group Example" --- # Leased Tag Group Example > 1. In the **Tag Browser**, click on the **Tag Group** ![](../../icons/taggroup.png) icon to open the **Tag Group Editor**. > 1. On the left side of the Tag Group Editor window, you can see all existing Tag Groups. Click on the **Add +** icon on the lower left side of the window to add a new Tag Group. > 1. Enter the name of the Tag Group. For example, you can name this new Tag Group **Leased**, and set the **Mode** to **Leased**. > 1. Set the **Rate** to 10,000ms (10 seconds) and the **Leased/Driven Rate** to 1,000ms (one second). > 1. Click **OK**. ## Add a Leased Tag Group Let's add a new Leased Tag Group that polls a tag from the PLC at a one second rate when someone needs to view that tag in the Client. If the Client is closed, the tags will poll at the standard Rate value. ![](img1.png) 1. Next, select the tags you want to use on the new Leased Tag Group. 1. Go to your Tag Browser, and select some tags you want to add to the Leased Tag Group. This example uses three Sine tags: Sine3, Sine4, and Sine5. 1. Right click on the selected tags, and click on **Edit tags**. ![](img2.png) 1. The Tag Editor will open showing you are editing multiple tags. From the Tag Group dropdown list, choose **Leased**, and click **OK**. ![](img3.png) You just created a new Leased Tag Group and added some tags. These tags are only polled quickly when a component that is bound to it is showing in a Client, Session, or when the tags are showing in the Designer. For example, these three Sine tags that are part of the Leased Tag Group are each bound to an LED component. ![](img4.png) :::note Remember that Tag History is stored based on the current Ignition tag value. If your Leased Tag Group has a **0** slow rate, you will not get updated data to store for history. Always make sure your Tag Group slow speed is at least as fast as your History Tag Group speed. :::
