--- title: "SQL Table Joins" --- # SQL Table Joins > Joins may look imposing at first, but they are simply SELECT statements that utilize columns from multiple tables. ## Overview The SQL JOIN allows you to run a single SELECT statement that references multiple tables. This can be used for more advanced filtering, as well as combining data from multiple tables in a single result set. The process of joining two tables involves stating both tables in the query, and then specifying that a column from one table relates to another in some way. The JOIN keyword works in conjunction with a SELECT statement. However, there are some key concepts that must be addressed when attempting to use the JOIN keyword. ### Specifying Each Column When listing column in a statement that uses the JOIN keyword, you must denote which table each column is being retrieved from. You can do this by using an [Alias](platform\sql-in-ignition\writing-sql-queries\sql-select-statements\sql-select-statements.md#aliases), or with the fully qualified column name. This prevents ambiguous columns in the context of the query, and makes it easier for you to use other keywords in the statement: i.e., adding WHERE clauses that apply to multiple tables. ```sql title="Pseudocode - Fully Qualified Column Name" table_name.column_name ``` ### Declare the Relation After the JOIN keyword, you must state which columns from each table relate to each other. This is accomplished by stating the name of the table, using the ON keyword, and then stating that a column on the first table is equal to a column on the second table. The columns specified are typically [primary keys](platform\sql-in-ignition\writing-sql-queries\writing-sql-queries.md#primary-key) for their respective tables. In the example below, we're stating that the values in **some_column** on **tableA** should be associated with matching values in **some_other_column** on **tableB**. ```sql title="Pseudocode - Using the Join Keyword" FROM TableA JOIN tableB ON tableA.some_column = tableB.some_other_column ``` The order you present the columns **after** the ON clause does not matter: A = B is equivalent to saying B = A, so we could switch the columns listed with no distinguishable impact on the resulting query ### Combining the Concepts Altogether, a basic JOIN looks like the following: ```sql title="Pseudocode - Join Syntax" SELECT tableA.column, tableB.column FROM tableA JOIN tableB ON tableA.identity_column = tableB.identity_column ``` ### Joins with Three or More Tables Joins can even be done between three or more tables. The syntax is similar, with each new table relation declared below the first. ```sql title="Pseudocode - Join Syntax" SELECT tableA.column, tableB.column, tableC.column FROM tableA JOIN tableB ON tableA.identity_column = tableB.identity_column JOIN tableC ON tableA.identity_column = tableC.identity_column ``` ## Join The standard JOIN, also referred to as INNER JOIN, will only return rows where the joined columns contain matching values. If one of the joined columns contains a value that is not present in the in the other, then the row is not represented in the result set. You would use JOIN when you only want results that are represented in both tables. ![" "](1-Join_InnerJoin.png) This section will demonstrate the various uses of the JOIN keyword. For the sake of clarity, the queries will run against tables that look like the following: #### Products Table | id | product_name | |----|--------------| | 1 | Apples | | 2 | Oranges | | 3 | Grapes | | 4 | Plums | #### Inventory Table | id | product_id | quantity | product_vendor | |----|------------|----------|------------------| | 1 | 1 | 15 | Apple Corp | | 2 | 2 | 25 | Orange Ya-Glad | | 3 | 3 | 56 | Grape Escape | | 4 | 5 | 45 | Banana Solutions | ### Join in Action In this demonstration, only rows that pertain to Apples, Oranges, and Grapes are being returned. We're using a JOIN between **products.id** and **inventory.product_id**, so our results will only contain rows that have matching values from both of those columns. Our result set does not contain any information on products with **products.id** values of 4 or **inventory.product_id** values of 5, because those values are not present in **both** of the joined columns. ```sql title="SQL - Joining Products and Inventory" SELECT products.id ,inventory.product_id ,products.product_name ,inventory.product_vendor ,inventory.quantity FROM products JOIN inventory ON products.id = inventory.product_id ``` #### Example Results | id | product_id | product_name | product_vendor | quantity | | -- | ---------- | ------------ | -------------- | -------- | | 1 | 1 | Apples | Apple Corp | 15 | | 2 | 2 | Orange | Orange Ya-Glad | 25 | | 3 | 3 | Grapes | Grape Escape | 56 | ## Left Join Return all rows from the left-most table (**table A** in the diagram), even if there are no matches on the right-most table (**table B**). If there isn't a matching record in the right table, then NULL values are returned. ![" "](2-Join_LeftJoin.png) ### Left Join in Action Here we see all rows returned from our products table (since it is the left-most table in our query). In row 4, columns that are being populated via the inventory table (**product_id**, **product_vendor**, and **quantity**) contain NULL values, because there isn't a row on the inventory table that matches with a **product_id** value of 4. The query must return something in this case, so it returns NULL for these columns. ```sql title="SQL - Left Joining Products and Inventory" SELECT products.id ,inventory.product_id ,products.product_name ,inventory.product_vendor ,inventory.quantity FROM products LEFT JOIN inventory ON products.id = inventory.product_id ``` #### Example Results | id | product_id | product_name | product_vendor | quantity | | -- | ---------- | ------------ | -------------- | -------- | | 1 | 1 | Apples | Apple Corp | 15 | | 2 | 2 | Orange | Orange Ya-Glad | 25 | | 3 | 3 | Grapes | Grape Escape | 56 | | 4 | NULL | Plums | NULL | NULL | ## Right Join Return all rows from the right-most table (**table B**), even if there are no matches on the left-most table (**table A**). If there isn't a matching record on the left table, then NULL values are returned. ![" "](3-Join_RightJoin.png) ### Right Join in Action When using a RIGHT JOIN, all rows will be returned from the inventory table. The products table does not have a row that contains an **id** value of 5, so the **id** and **product_name** columns will show NULL values in our result set. ```sql title="SQL - Right Joining Products and Inventory" SELECT products.id ,inventory.product_id ,products.product_name ,inventory.product_vendor ,inventory.quantity FROM products RIGHT JOIN inventory ON products.id = inventory.product_id ``` #### Example Results | id | product_id | product_name | product_vendor | quantity | | ---- | ---------- | ------------ | ---------------- | -------- | | 1 | 1 | Apples | Apple Corp | 15 | | 2 | 2 | Orange | Orange Ya-Glad | 25 | | 3 | 3 | Grapes | Grape Escape | 56 | | NULL | 5 | NULL | Banana Solutions | 45 | ## Full Join The FULL JOIN returns all rows from both tables, regardless if there are matching values in the joined columns. You would use a FULL JOIN in cases where you want to show all applicable records from both tables, and synchronize the data across both tables via the joining columns where possible. ![" "](4-Join_FullJoin.png) ### Full Join in Action Note that we're using the same query as the standard JOIN, but we've prepended "FULL" to the last line of the query. Note the NULL values returned in cases where our product ID is not fully represented on both tables. ```sql title="SQL - Full Joining Products and Inventory" SELECT products.id ,inventory.product_id ,products.product_name ,inventory.product_vendor ,inventory.quantity FROM products FULL JOIN inventory ON products.id = inventory.product_id ``` #### Example Results | id | product_id | product_name | product_vendor | quantity | | ---- | ---------- | ------------ | ---------------- | -------- | | 1 | 1 | Apples | Apple Corp | 15 | | 2 | 2 | Orange | Orange Ya-Glad | 25 | | 3 | 3 | Grapes | Grape Escape | 56 | | 4 | NULL | Plums | NULL | NULL | | NULL | 5 | NULL | Banana Solutions | 45 | ### Full Joins in MySQL MySQL does not have an equivalent FULL JOIN. However, you can emulate one by utilizing a LEFT JOIN, RIGHT JOIN, and the UNION keyword. For the sake of simplicity, we will return all columns in the following example, but you would still want to specify individual columns in both SELECT query. ```sql title="SQL - Full Join in MySQL using Left Join, Right Join, and Union Keyword" SELECT * FROM products LEFT JOIN inventory ON products.id = inventory.product_id UNION ALL SELECT * FROM products RIGHT JOIN inventory ON products.id = inventory.product_id WHERE products.id IS NULL ```
