--- title: "Using Named Queries - Example" --- # Using Named Queries - Example > We are going to be querying a table in the database that holds information about products stored in storage bays. The database table is named "containers" and has the following structure. ## A Named Query Example Here we will go over the steps necessary to put together a basic named query. This example will create a Named Query that uses a single parameter to run a select query, and then add a Table to a window and create a binding that uses our new Named Query. |id|StorageBay|ContainerType|ItemName|Weight|Time| |--|--|--|--|--|--| |1|1 |Jug |Vanilla |25.2 |2017-06-25 15:58:47 | |6|1 |Mason Jar |Chocolate |12.3 |2017-06-26 16:05:27 | |18 |2 |Tray |Swiss Cheese |88.8 |2017-06-25 01:21:31 | |22 |3 |Tray |Cheddar Cheese |54.7 |2017-06-25 03:52:16 | |23 |3 |Basket |Strawberry |36.8 | 2017-06-25 15:56:03| |31 |3 |Jug |Whole Milk |80.1 |2017-06-27 09:51:31 | |32 |3 |Jug|Fat Free Milk |76.9 |2017-06-27 09:52:52 | If you want to follow along with the example, feel free to make a database table that looks similar to this one and add as many rows of data as you would like, otherwise, you can use your own and substitute in the proper column names from your database. ### Creating a Named Query and Adding Security 1. Start by opening up the Designer and loading a project. 2. Locate the Named Query section of the project browser, right click on it, and select the **New Query** ![](image2019-05-28_13-49-54.png) option. ![](image2019-05-20_10-31-30.jpg) 3. You should now have a fresh Named Query that you can rename whatever you want. We used **FirstNamedQuery** in the example. ![](image2019-05-20_10-55-57.jpg) 4. To set up security on the Named Query, set required Security Zone and Role combinations in the Security table of the Settings tab. You can leave this blank if you don't have [roles](platform\security\classic-authentication-strategy\managing-users-and-roles\managing-users-and-roles.md) or [zones](platform\security/security-zones/security-zones.md) set up yet. 5. If multiple security combinations are required, use the Add (![](image2017-6-28_10-16-52.png)) icon to add additional rows. ![](image2019-05-20_11-10-40.jpg) ### Building the Query 1. Click on the **Authoring** tab. Here is where we do most of the work. 2. Under **Database Connection**, we need to select a database connection that this named query will use. We selected **<Default>**. 3. For the **Query Type**, we can decide what type of query this will be. For this example, We am running a select query that will return a dataset, so we choose **Query**. 4. In the Parameters section, we can decide on a list of parameters that will be used in this query. This query is fairly simple, and will only use a single parameter. Click the Add (![](image2017-6-28_10-16-52.png)) icon to add a new parameter and set the following values: * **Type**: Parameter * **Name**: BayNum * **Data Type**: Integer 5. The Query section below is where we construct our query using the Table Browser. 1. Right click on the containers table in the Table Browser on the right, and click on **Create SELECT Statement**. This will populate our query field with a basic select all statement. 2. Type into the **Query** field and add the following WHERE clause: **"WHERE StorageBay = "** 3. Now drag the **BayNum** parameter from the Parameters table to the end of the query you just typed. Notice "**:BayNum**" will be added at the end of the query. ![](image2019-05-20_11-15-54.jpg) ### Using the Query 1. In the Project Browser, create or open a [Main Window](ignition-modules\vision\vision-windows\vision-windows.md). 2. Drag a **Dropdown List** component onto the window. 3. The Dropdown List is where we will be able to select a Bay Number to use as our Named Query's BayNum Parameter. Use the [Dataset Viewer](ignition-modules\vision\common-tasks-in-vision\dropdown-list-example\dropdown-list-example.md) to set the **Data** property of the Dropdown to look like this: |Value|Label| |--|--| |1 |Bay 1 | |2 |Bay 2 | |3 |Bay 3 | ![](image2019-05-28_10-42-31.png) 4. Now drag a **Table** component onto the window. We can setup a Named Query binding on the Data property. 5. Click on the **Binding** (![]()) icon for the **data** property and select the **Named Query** binding type. 6. Set the Path property by clicking on the **Select Resource Path** (![](image2017-6-28_13-22-8.png)) icon and selecting your new Named Query from the list. For this example, it is **FirstNamedQuery**. Alternately, you can type the name in. 7. Highlight your **BayNum** Parameter (in the Parameters table) and click on the Insert Property (![](image2017-6-28_13-26-31.png)) icon. We want to select the **Selected Value** property of our Dropdown List. 8. Finally, we want to ensure the Polling Mode is set to **Off**. This means the query will not run continuously, but will only run when it changes such as when a new bay is selected from the dropdown. 9. Click the **OK** button to save your binding, and put your Designer into **Preview Mode** (![Preview Mode Icon](preview-mode-icon.png)) to test it. We can then make a selection (i.e., Bay 3) with our dropdown, and see our table populate with data. ![](image2019-5-20_11-28.png)
