--- title: "Conditions and Loops" --- # Conditions and Loops > ```python title="Pseudocode - If Statement" > Note that 'if' uses lowercase characters. > Additionally, a colon is placed after the expression. > if expression: > > # The statements that should execute when the expression is true > # MUST be indented. > statement > ``` ## If-Statements The **if** statement should be familiar to anyone with a passing knowledge of programming. The idea of an **if** is that you want your script to execute a block of statements only when a certain condition is true. Python's **if** is simple to use, and has some additional keywords to provide more flexibility. ### Simple If-Statement Example The syntax for **if** is as follows: ```python title="Pseudocode - If Statement" # Note that 'if' uses lowercase characters. # Additionally, a colon is placed after the expression. if expression: # The statements that should execute when the expression is true # MUST be indented. statement ``` |Example |Output | |--|--| |
x = 5z = 15if x < 10: # Since the condition "x < 10" is true, # the following line will execute print "'x' is less than 10"if z < 10: # This condition "z < 10" is false, # so the following line will not execute print "this will never show"|'x' is less than 10 ### If and Else You can use the **if...else** form of an **if** statement to do one thing if a condition is true, and something else if the condition is false. |Example |Output | |--|--| |
x = 15if x < 10: print "x is less than 10"else: print "x is not less than 10"|x is not less than 10 | ### Elif (Else If) Lastly, you can use the **if...elif** form. This form combines multiple condition checks. `elif` stands for `"else if"`. This form can optionally have a catch-all `else` clause at the end. For example, this script will print out three: |Example |Output | |--|--| |
x = 3if x == 1: print "one"elif x == 2: print "two"elif x == 3: print "three"else: print "not 1-3"|three You can use as many elif items as you want, and the else is not required at the end. ## For-Loops and While-Loops ### For-Loop Python's **for** loop may be a bit different than what you're used to if you've programmed any C. The **for** loop is specialized to iterate over the elements of any sequence, like a list. A **for** loop uses an iterator variable to reference each item as it steps through the sequence. This means it's very simple to write a loop! Note that the syntax of the for-loop requires use of the in-keyword. ```python title="Pseudocode - For Loop" # In this example, "item" is a variable created specifically by the "for" loop to act as an iterator. # The name "item" is not a keyword, and a different variable name may be used. # Additionally, note that "for" and "in" are lowercase, and a colon is present at the end of the line. for item in sequence: # All statements that should execute each iteration must be indented after the "for" statement statement ``` |Example |Output | |--|--| |
listOfFruit = ['Apples', 'Oranges', 'Bananas']for fruit in listOfFruit: print fruit|ApplesOrangesBananas | You don't need to manually create a sequence to repeat a task several times in a for loop. Instead, the built-in function **range()** function can generate a variable-size list of integers starting at zero. For example, calling **range(4)** will return the list [0, 1, 2, 3]. |Example |Output | |--|--| |
# Even though this example isn't using the value of "x",# the print statement will still be executed once for each item# in the list returned by range().for x in range(4): print "this will print 4 times"|this will print 4 timesthis will print 4 timesthis will print 4 timesthis will print 4 times | ### While-Loop A while loop will repeat a block of statements as long as a condition is true. This code will print out the contents of the items in the list. ```python title="Pseudocode - While Loop" # A while loop simply needs the keyword "while", the condition that # determines when we should stop iterating, and a colon at the end of the line. while condition: # All statements that should be repeated each iteration must be indented after the "while" statement statement. ``` This code uses a function called **len()**, which is a built-in function that returns the length of a sequence. |Example |Output | |--|--| |
listOfFruit = ['Apples', 'Oranges', 'Bananas']x = 0while x < len(listOfFruit): print listOfFruit[x] x = x + 1|ApplesOrangesBananas | ### The Break and Continue Statements You can stop a loop from repeating in its tracks by using the **break** statement. This code will print out " Loop " exactly two times, and then print " Finished ". |Example |Output | |--|--| |
for x in range(10): if x >= 2: break print "Loop"print "Finished"|LoopLoopFinished | You can use the **continue** statement to make a loop stop executing its current iteration and skip to the beginning of the next iteration. The following code will print out the numbers 0-9, skipping 4. |Example |Output | |--|--| |
for x in range(10): if x == 4: continue print x|012356789 | #### Infinite Loops It is incredibly easy to create an infinite loop when using a **while** statement. Depending where the infinite loop was created, it could cause you to lose your work in the Designer, or create a large amount of overhead on the Gateway. ```python title="Python - Infinite Loop Created by While Statement" x = 0 while x < 10: x += 1 # Forgetting to add a way to increment "x" will cause an infinite loop print x ``` In many cases, a **for** loop could be used instead of a **while**, but this is not always possible. When using **while**, the best way to avoid an infinite loop is to make sure you always have a way to exit the loop: a simple approach involves using a counter that can eventually trigger a **break** statement, or add the counter as an additional condition to the **while**. ```python title="Python - Preventing Infinite Loops Using the Break Keyword" ###Example 1: using the break keyword # The counter variable will be used as a guaranteed way out of the While. counter = 0 # Normally, using True as a condition in a While would be a quick # way to generate an infinite loop, but the counter helps prevent that while (True): # Increase the counter counter += 1 # Check the value of the counter. If it's at the point where we can assume we're going to be looping indefinitely... if counter >= 1000: # Break out of the loop break ``` ```python title="Python - Preventing Infinite Loops Using an Additional Condition" ###Example 2: using an additional condition # Again, the counter variable will be used as a guaranteed way out of the While. counter = 0 # Instead of using nested logic, we can simply add counter's value as an additional condition with "and" while (True and counter < 1000): # Increase the counter. Once counter >= 1000, the while loop will be forced to end. counter += 1 ``` ## The Pass Keyword When using conditional statements and loops, the pass keyword can be especially useful when writing a new script. When called, the pass keyword does nothing, which may seem useless. However it is great when you find yourself in a situation where you need a line of code to meet a syntax requirement, but don't want the code to do any additional work. ```python title="Python - Pass Keyword" myVar = system.tag.read(tagPath).value if myVar == 0: firstFunction() elif myVar == 1: secondFunction() elif myVar == 2: # I haven't implemented the thirdFunction() yet, so I can use pass here as a placeholder pass ```
