--- title: "Localization and Languages" --- # Localization and Languages > Localization lets you display projects in multiple languages. Translations are stored in the Gateway and can be used in Perspective sessions, Vision clients, alarms, and scripts. This allows users in different regions to view the same project in their preferred language without additional setup in each project. ## Translating Ignition In Perspective, localization is configured by mapping component text to translation keys and setting the session's locale. When the locale changes, the text updates automatically. For example, you can provide a dropdown that switches the session from English to Spanish. Vision also supports localization through the same translation database, and it can define component-level terms through the [Translatable Terms panel](#using-the-translatable-terms-panel-in-vision). Vision projects can also use tools such as the [Language Selector](appendix/components/vision-components/input/language-selector/language-selector.md) component. ## Translation Manager All translations are stored in a shared database that makes it possible to manage terms in one place and apply them to any project. Translation functionality is available in Perspective session, Vision Clients, Gateway scripts, and alarm messages. Translation support is built into component text properties and other text-based properties, such as with alarm messages. In most cases, once a translation is defined, no additional configuration is needed for it to be applied. You can view and edit the translation database in the Translation Manager panel in the Designer. Use the Translation Manager to add, edit, or remove terms. You can create translations for single words or longer phrases, define new languages, and [import and export](platform/localization-and-languages/creating-translation-lists/creating-translation-lists.md) translation lists. ![](translation-manager-panel.png) To open the Translation Manger panel, go to the menu bar and select **Tools** > **Translation Manager**. ![](enable-translation-manager-panel-1.png) To add the panel to your Designer interface, go to the menu bar and select **View** > **Panels** > **Translation Manager**. ![](enable-translation-manager-panel-2.png) ## Translation Database and Term Lookup Translations are stored in the Gateway's database as **keys**. A key is the base term Ignition uses to look up the correct translation. Keys can be simple text such as **Start**, or coded identifiers such as **START_COMMAND** or **#start**. Using coded identifiers helps avoid accidental matches and makes terms easier to reuse across projects. When a component property references a key, Ignition checks the translation database for a matching entry in the active language. If no match is found, the English value is displayed by default. In Perspective, you assign a key to a component property in the Property Editor. When the session's locale changes, all components bound to that key automatically update to display the correct translation. ### Using the Translatable Terms Panel in Vision In Vision, you can view and edit translation keys directly in the Translatable Terms panel. To open it, go to the menu bar and select **View** > **Panels** > **Translatable Terms**. ![](enable-translatable-terms-panel.png) The panel shows each term for the components in the current window, along with the translations available for the active language. ![](translatable-terms-panel.png) ## Previewing Translations In Perspective, you can preview translations by changing the session's locale. In the Designer, select **Perspective** in the Project Browser to open the [Session Properties](ignition-modules/perspective/perspective-sessions/session-properties.md), then set **locale** to the desired language. You can update the locale in a running session through scripting or bindings. When the locale changes, all text mapped to translation keys updates automatically. ![](session-props-locale.png) In Vision, you can preview translations by setting a Preview Language in the Designer. Go to the menu bar, select **Project** > **Preview Language** and choose a language. When you switch to Preview Mode, text in the window updates to the selected language. You can also use the Language Selector component or a script to temporarily change the language. The Designer remembers your preview language even after a restart, but it reverts whenever Preview Mode is disabled. ![](preview-language.png)
