--- title: "Output Console" --- # Output Console > The Output Console is a dockable panel that you can open via Tools > Script Console menu or the Ctrl-Shift-C keyboard shortcut. The Output Console prints system messages that are coming from the Designer. This can vary from simple info messages that show when things are loaded, to error messages when something goes wrong. The Console is also frequently used to test and debug Python scripts, as print statements on components that are run in the Designer are printed here. ![](img1.png) For example, by using the **print** function in your script, you can observe the inner workings of your script as it executes. If you executed the following script: ``` # A Python script that demonstrates the print statement. print "Print me first" x=10 z=2 print x, y, x/y #Result looks like this: #Print me first #10 2 5 ``` :::note Gateway-scoped information will not appear in either the Output Console or [Script Console](../script-console/script-console.md). Instead, the output will be sent to the [wrapper.log file](platform\gateway\status\diagnostics-logs\wrapper-logs\wrapper-logs.md). Alternatively, [system.util.getLogger()](../../../../appendix/scripting-functions/system-util/system-util-getLogger.md) will send messages to the Gateway Console, and is a preferred method of troubleshooting Gateway scoped scripts. ::: :::info You can use certain options, such as copying, in the Edit Menubar at the top of the Designer window. ::: The Output Console is most frequently used to test and debug Python scripts on components in Ignition. By using the **print** keyword in your script, you can observe the inner workings of your script as it executes. For example, if you executed the following script: ```python title="Python - Using the Output Console to Test and Debug Python Scripts" # A function that intercepts tag writes, printing out the previous value first. def writeToTag(path, value): prevValue = system.tag.getTagValue(path) print "Writing value '%s' to %s, was previously '%s'" % (value, path, prevValue) system.tag.writeToTag(path, value) writeToTag("Compressor/HOA", 2) ``` It would print the following to the console: Writing value '2' to Compressor/HOA, was previously '0' :::note The Output Console is also available in the Vision Client from **Help** > **Diagnostics** and selecting the **Console** tab. :::
