--- title: "Installing IBM DB2" description: "To Download IBM DB2 Community Edition" --- # Installing IBM DB2 > To Download IBM DB2 Community Edition You need to install **IBM DB2 Community Edition** before you connect to the database. ## To Download IBM DB2 Community Edition 1. Go to the [Db2 Download](https://www.ibm.com/account/reg/us-en/signup?formid=urx-33669) page and sign in with your IBM credentials. 2. Download the IBM® Db2 11.5 Edition for your Operating System. 3. Log on to your system using a local administrator account. 4. Locate the `v11.5_ntx64_dec.zip` file that you downloaded and extract it to your desired location. 5. In the extracted folder, right-click on the setup.exe file and select **Run as administrator**. 6. Click **Install a Product** 7. Scroll down to the end of the `Db2 Version 11.5.0.0 Server Editions` section and click **Install New**, then click **Next** to begin the installation process. 8. Review and accept the software license agreement and click **Next**. 9. Select the **Typical** Installation option and then click **Next**. 10. Select **Install Db2 Server Edition on this computer and save my settings in a response file** and click **Next**. 11. Set your installation path and click **Next**. 12. Set your **DB2 copy name** and click **Next**. 13. Select **Local user or Domain user account** and enter your user credentials. 14. Select **DB2** as the default instance and click **Next**. 15. Uncheck the **Set up your DB2 server to send notifications checkbox** and click **Next**. 16. Select the **Enable operating system security** checkbox and click **Next**. 17. Click **Finish** to finalize your installation. :::note For detailed instructions, refer to the links below: [Installing the Db2 server by using the Db2 Setup wizard (Windows)](https://www.ibm.com/docs/en/db2/11.5?topic=idds-installing-db2-database-servers-by-using-db2-setup-wizard-windows) [Installing the Db2 server by using the Db2 Setup wizard (Linux and UNIX)](https://www.ibm.com/docs/en/db2/11.5?topic=idds-installing-db2-servers-by-using-db2-setup-wizard-linux-unix) [Downloading and Installing Docker Editions](https://www.ibm.com/docs/en/db2/11.5?topic=docker-downloading-installing-editions) The links above are for the IBM DB2 Database version 11.5. You can change the instruction version by using the drop-down list located on the top left side ::: After you have successfully installed IBM DB2, you will need to create a database. ## Creating a database in Windows 1. Open Command Prompt with Administrator privileges. 2. Type `db2cmd` (This will open the DB2 Command Line Tool) 3. Type `db2` (This will open the Command Line Processor for DB2 Client) 4. To create a database: `CREATE DATABASE database_name` :::note IBM Documentation on Creating Databases: [Creating Databases](https://www.ibm.com/docs/en/db2/11.5?topic=databases-creating) :::
