--- title: "JDBC Driver and Database Translator Settings" description: "This page details various JDBC driver and translator settings." --- # JDBC Driver and Database Translator Settings > This page details various JDBC driver and translator settings. This page details various JDBC driver and translator settings. See the [JDBC Drivers and Translators page](platform\database-connections\connecting-to-databases\jdbc-drivers-and-translators\jdbc-drivers-and-translators.md#add-a-new-jdbc-driver) for information on adding and configuring JDBC drivers and translators. ## IBM ### IBM Default JDBC Driver Settings #### Main Properties |Property|Value| |---|---| |Name|IBM DB2| |Description|The official IBM DB2 JDBC Driver.| |Classname|com.ibm.db2.jcc.DB2Driver| |JAR File(s)|Click on the Choose File button to select and upload the JAR(s). This is the part where you upload the JDBC driver.| #### Driver Defaults & Instructions |Property|Value| |---|---| |Driver Type|DB2| |URL Format|jdbc:db2://localhost:50000/SAMPLEORjdbc:db2://localhost:25000/SAMPLE| |URL Instructions|The format of the DB2 connect URL is:db2://**host**:**port**/**database**With the three parameters (in bold)**host**: The host name or IP address of the database server.**port**: The port that the database server is running on. DB2 default port is **50000**.**database**: The name of the logical database that you are connecting to on the DB2 server.| |Default Connection Properties|Blank| |Connection Property Instructions|Blank| |Default Validation Query|select 1 from sysibm.sysdummy1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|The Translator this driver should use. Default: IBM DB2| ### IBM Default Translator Settings #### Main Properties |Property|Value| |---|---| |Name|(Name of the Translator. The JDBC driver will reference the settings below by the name specified here)| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|Blank| |Create Trigger Syntax|Blank| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|`{type} GENERATED ALWAYS AS IDENTITY PRIMARY KEY`| |Alter Table Syntax|`ALTER TABLE {tablename} {alterdef}`| |Add Column Syntax|`ADD COLUMN {columnname} {type}`| |Primary Key Syntax|Blank| |Limit Syntax|`FETCH FIRST {limit} ROWS ONLY`| |Limit Position|Back| |Current Timestamp Query| The value's current timestamp.| |Column Quote Character|"| |Supports Returning Auto-generated Keys?|False| |Fetch Key Query|`SELECT max({columnname}) FROM {tablename}`| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|bigint| |Boolean|int| |Datetime|timestamp| |Float (R4)|float| |Double (R8)|double| |String|varchar(255)| |Binary|blob| |Long Text|clob(65536)| ## MySQL ### MySQL Default JDBC Driver Settings #### Main Properties |Property|Value| |---|---| |Name|MySQL| |Description|The official MySQL JDBC Driver, Connector/J.| |Classname|com.mysql.cj.jdbc.Driver| |JAR File(s)|Click on the **Choose File** button to select and upload the JAR(s). This is the part where you upload the JDBC driver.| #### Driver Defaults & Instructions |Property|Value| |---|---| |Driver Type|MySQL| |URL Format|jdbc:mysql://localhost:3306/test| |URL Instructions|The format of the MySQL connect URL is:jdbc:mysql://**host**:**port**/**database**With the three parameters (in bold) **host**: The host name or IP address of the database server.**port**: The port that the database server is running on. MySQL default port is **3306**.**database**: The name of the logical database that you are connecting to on the MySQL server.| |Default Connection Properties|zeroDateTimeBehavior=CONVERT_TO_NULL;connectTimeout=120000;socketTimeout=120000;useSSL=false;allowPublicKeyRetrieval=true;| |Connection Properties Instructions|There is an extensive list of extra connection properties available for MySQL Connector/J. See [the documentation](https://dev.mysql.com/doc/connectors/en/connector-j-reference-configuration-properties/) for a table describing all connection properties.A default `serverTimezone` value (taken from the Gateway) will be appended to the connection string if one is not specified.| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|MySQL| ### MySQL Default Translator Settings #### Main Properties |Property|Value| |---|---| |Name|MySQL| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|Blank| |Create Trigger Syntax|Blank| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|`{type} NOT NULL AUTO_INCREMENT`| |Alter Table Syntax|`ALTER TABLE {tablename} {alterdef}`| |Add Column Syntax|`ADD COLUMN {columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY ({columnname})`| |Limit Syntax|`LIMIT {limit}`| |Limit Position|Back| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP`| |Column Quote Character|`| |Supports Returning Auto-generated Keys?|True| |Fetch Key Query|Blank| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|bigint| |Boolean|int| |Datetime|datetime| |Float (R4)|float(10)| |Double (R8)|double| |String|varchar(255)| |Binary|varbinary| |Long Text|text| ## MSSQL ### MSSQL Default JDBC Driver Settings #### Main Properties |Property|Value| |---|---| |Name|Name of the driver, as you would like it to appear on the Gateway.| |Description|Enter a useful description you would like to see next to the driver.| |Classname|com.microsoft.sqlserver.jdbc.SQLServerDriver| |JAR File(s)|Click on the Choose File button to select and upload the JAR(s). This is the part where you upload the JDBC driver.| #### Driver Defaults & Instructions |Property|Value| |---|---| |Driver Type|Microsoft SQL Server| |URL Format|jdbc:sqlserver://localhost\SQLEXPRESS| |URL Instructions|The format of the SQL Server connect URL is:jdbc:sqlserver:// **host** \ **instanceName** [:**port**] With the three parameters (in bold) **host**: The host name or IP address of the database server.**instanceName**: (optional) the instance to connect to on the host. If not specified, a connection to the default instance is made.**port**: (optional) the port to connect to. The default is **1433**. If you are using the default, you can omit the port and the preceding ':'. For SQL Server, you specify the **database name** to connect to using the `databaseName` property in the **Extra Connection Properties**.| |Default Connection Properties|databaseName=test| |Connection Properties Instructions|Use `databaseName=YOUR_DATABASE` to specify the database to connect to.| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|The Translator this driver should use.| ### MSSQL Default Translator Settings #### Main Properties |Property|Value| |---|---| |Name|Name of the Translator. The JDBC driver will reference the settings below by the name specified here.| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|Blank| |Create Trigger Syntax|Blank| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|`{type} IDENTITY(1,1)`| |Alter Table Syntax|`ALTER TABLE {tablename} ADD {alterdef}` | |Add Column Syntax|`{columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY CLUSTERED ({columnname})`| |Limit Syntax|`TOP {limit}`| |Limit Position|Front| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP`| |Column Quote Character|"| |Supports Returning Auto-generated Keys?|True| |Fetch Key Query|Blank| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| \Long (I8)|bigint| |Boolean|int| |Datetime|datetime| |Float (R4)|float(10)| |Double (R8)|double precision| |String|varchar(255)| |Binary|varbinary| |Long Text|nvarchar(max)| ## Oracle Express ### Oracle Express Default JDBC Driver Settings #### Main Properties |Property|Value| |---|---| |Name|Name of the driver, as you would like it to appear on the Gateway.| |Description|Enter a useful description you would like to see next to the driver.| |Classname|oracle.jdbc.driver.OracleDriver| |JAR File(s)|Click on the Choose File button to select and upload the JAR(s). This is the part where you upload the JDBC driver.| #### Driver Defaults & Instructions |Property|Value| |---|---| |Driver Type|Oracle| |URL Format|jdbc:oracle:thin:@localhost:1521:test| |URL Instructions|The format of the Oracle connect URL is:jdbc:oracle:thin:@ **host** : **port** : **SID** With the three parameters (in bold) **host**: The host name or IP address of the database server.**port**: The port that the database server is running on. Oracle's default port is **1521**.**SID**: the system ID that identifies the database to connect to.| |Default Connection Properties|Blank| |Connection Properties Instructions|Blank| |Default Validation Query|SELECT 1 FROM DUAL| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|The Translator this driver should use.| ### Oracle Express Default Translator Settings #### Main Properties |Property|Value| |---|---| |Name|Name of the Translator. The JDBC driver will reference the settings below by the name specified here| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|`CREATE SEQUENCE {tablename}seq START WITH 1 INCREMENT BY 1`| |Create Trigger Syntax|`CREATE TRIGGER {tablename}trig BEFORE INSERT ON {tablename} REFERENCING NEW AS NEW FOR EACH ROW BEGIN select {tablename}seq.nextval INTO :NEW.{columnname} FROM dual; END;`| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|`{type} NOT NULL`| |Alter Table Syntax|`ALTER TABLE {tablename} ADD ({alterdef})`| |Add Column Syntax|`{columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY ({columnname})`| |Limit Syntax|`rownum<={limit}`| |Limit Position|Wrap| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP FROM DUAL`| |Column Quote Character|"| |Supports Returning Auto-generated Keys?|False| |Fetch Key Query|`SELECT {tablename}SEQ.CURRVAL FROM DUAL`| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|int| |Boolean|int| |Datetime|timestamp| |Float (R4)|float| |Double (R8)|double precision| |String|varchar2(255)| |Binary|varbinary| |Long Text|nclob| ## PostgreSQL ### PostgreSQL Default JDBC Driver Settings #### Main Properties |Property|Value| |---|---| |Name|Name of the driver, as you would like it to appear on the Gateway.| |Description|Enter a useful description you would like to see next to the driver.| |Classname|org.postgresql.Driver| |JAR File(s)|Click on the Choose File button to select and upload the JAR(s). This is the part where you upload the JDBC driver.| #### Driver Defaults & Instructions |Property|Value| |---|---| |Driver Type|PostgreSQL| |URL Format|jdbc:postgresql://localhost:5432/test| |URL Instructions|The format of the PostgreSQL connect URL is:jdbc:postgresql://**host**:**port**/**database**With the three parameters (in bold) **host**: The host name or IP address of the database server.**port**: The port that the database server is running on. PostgreSQL default port is **5432**.**database**: The name of the logical database that you are connecting to on the PostgreSQL server.| |Default Connection Properties|Blank| |Connection Properties Instructions|No extra connection parameters are recommended for PostgreSQL. For possible parameter values, see the documentation at the [PostgreSQL JDBC driver website](http://jdbc.postgresql.org).| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|The Translator this driver should use. | ### PostgreSQL Default Translator Settings #### Main Properties |Property|Value| |---|---| |Name|Name of the Translator. The JDBC driver will reference the settings below by the name specified here| |Create Table Syntax|`CREATE TABLE {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|Blank| |Create Trigger Syntax|Blank| |Create Index Syntax|`CREATE INDEX {indexname} ON {tablename}({columnname})`| |Auto Increment Field Definition|SERIAL NOT NULL| |Alter Table Syntax|`ALTER TABLE {tablename} {alterdef}`| |Add Column Syntax|`ADD COLUMN {columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY ({columnname})`| |Limit Syntax|`LIMIT {limit}`| |Limit Position|Back| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP`| |Column Quote Character|"| Supports Returning Auto-generated Keys?|True| |Fetch Key Query|Blank| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|bigint| |Boolean|int| |Datetime|timestamp| |Float (R4)|float| |Double (R8)|double precision| |String|varchar(255)| |Binary|bytea| |Long Text|text| ## Snowflake ### Snowflake Default JDBC Driver Settings :::note Many of the fields for the Snowflake JDBC driver can be left blank if your custom Snowflake translator is set up properly and referenced in the "Default Translator" field. ::: Due to security updates in Java 17, Snowflake JDBC drivers may not interact correctly with Ignition. This can be fixed by adding the following Java argument to the [Gateway Configuration File](appendix\reference-pages\gateway-configuration-file-reference\gateway-configuration-file-reference.md#changing-java-additional-parameters): ``` wrapper.java.additional.1=--add-opens=java.base/java.nio=ALL-UNNAMED ``` See the official [Snowflake Knowledge Base](https://community.snowflake.com/s/article/JDBC-Driver-Compatibility-Issue-With-JDK-16-and-Later) for more information about this issue. #### Main Properties |Property|Value| |---|---| |Name|Name of the driver, as you would like it to appear on the Gateway.| |Description|Enter a useful description you would like to see next to the driver.| |Classname|net.snowflake.client.jdbc.SnowflakeDriver| |JAR File(s)|Click on the **Choose File** button to select and upload the JAR(s). This is the part where you upload the JDBC driver.| #### Driver Defaults & Instructions |Property|Value| |---|---| |Driver Type|Generic| |URL Format|Blank| |URL Instructions|Blank| |Default Connection Properties|Blank| |Connection Properties Instructions|Blank| |Default Validation Query|SELECT 1| #### SQL Language Compatibility |Property|Value| |---|---| |Default Translator|Your custom Snowflake Translator.| ### Snowflake Default Translator Settings :::note If you have a database table called "NO_OP_TABLE", you should use a different table name for the "Create Index Syntax" field. ::: #### Main Properties |Property|Value| |---|---| |Name|Name of the translator, as you would like it to appear on the Gateway.| |Create Table Syntax|`CREATE TABLE IF NOT EXISTS {tablename} ({creationdef}{primarykeydef})`| |Create Sequence Syntax|`CREATE SEQUENCE IF NOT EXISTS {tablename}seq`| |Create Trigger Syntax|Blank| |Create Index Syntax|`ALTER TABLE IF EXISTS NO_OP_TABLE SET COMMENT='no-op table due to forced value for TRANSLATORS < ALTER TABLE SYNTAX;`| |Auto Increment Field Definition|`{type} NOT NULL AUTOINCREMENT`| |Alter Table Syntax|`ALTER TABLE {tablename} {alterdef}`| |Add Column Syntax|`ADD COLUMN {columnname} {type}`| |Primary Key Syntax|`PRIMARY KEY ({columnname})`| |Limit Syntax|`LIMIT {limit}`| |Limit Position|Back| |Current Timestamp Query|`SELECT CURRENT_TIMESTAMP`| |Column Quote Character|Blank| |Supports Returning Auto-generated Keys?|False| |Fetch Key Query|`SELECT NEXT_VALUE FROM INFORMATION_SCHEMA.SEQUENCES WHERE SEQUENCE_NAME='{tablename}'`| |Table List Filter|Blank| #### Data Type Mapping |Name|Type| |---|---| |Byte (I1)|int| |Short (I2)|int| |Integer (I4)|int| |Long (I8)|bigint| |Boolean|int| |Datetime|datetime| |Float (R4)|float| |Double (R8)|double| |String|string| |Binary|binary| |Long Text|text| :::note In addition to a custom JDBC driver and custom translator, you may need to also configure the `Connection Initialization Commands` property in your Snowflake [database connection](platform\database-connections\database-connections.md) to properly store Tag History. Add the following values to the `Connection Initialization Commands` property: * USE DATABASE ignition_db * USE SCHEMA ignition_db.time_series :::
