--- title: "Connecting to IBM DB2" description: "In order to connect Ignition to IBM DB2 you must have a Translator, a Driver, and a Database Connection." --- # Connecting to IBM DB2 > In order to connect Ignition to IBM DB2 you must have a Translator, a Driver, and a Database Connection. ## IBM DB2 Connection Requirements The Translator and Driver only need to be configured once. You can make as many connections as you want to any compatible IBM DB2 database. ## Connect to IBM DB2 1. On the Gateway Webpage, go to the **Config** section. 2. Scroll down to **Databases > Connections**. ![" "](ibmDatabases-Connections.png) 3. The Database Connections page is displayed. Click on **Create new Database Connection....** ![" "](ibmCreate-New-Database-Connections.png) 4. Select **IBM DB2 JDBC Driver**, and click **Next**. ![" "](ibmDriver.png) :::note For more information, see [JDBC Drivers and Translators](platform\database-connections\connecting-to-databases\jdbc-drivers-and-translators\jdbc-drivers-and-translators.md#common-third-party-drivers) for instructions on obtaining the requisite JAR file, and then follow the steps for [Upgrading a JDBC Driver](platform\database-connections\connecting-to-databases\jdbc-drivers-and-translators\jdbc-drivers-and-translators.md#upgrade-a-jdbc-driver) before continuing with these instructions. ::: 5. On the New Database Connection page, enter the following information: * Name: **IBM_DB2** * Connect URL: **jdbc:db2://localhost:25000/SAMPLE** :::info If on Db2 Version 11.5.5 and older, the default port number is 50000. If on Db2 Version 11.5.6 and newer, the default port number is 25000. ::: * Username: **your_username** * Password: **your_password** ![" "](ibmUsername-Password.png) 6. At the bottom of the form, click on **Create New Database Connection**. Your connection is now created. The Database Connections page is displayed and will show the status of Reconnecting, then Valid. ![" "](ibmConnection-Success.png) 7. To display the details about the status of your database connection, see the **Note** on the above window and click on the **Database Connection Status** link. ![" "](ibmConnection-Status.png) ## Troubleshooting ### Troubleshooting Tools [IBM DOC - Troubleshooting Tools](https://www.ibm.com/docs/en/db2/11.5?topic=techniques-troubleshooting-tools) ### Installation Issues DB2 installation fails to create instance and DAS: [IBM DOC - DB2 installation fails to create instance and DAS](https://www.ibm.com/support/pages/db2-installation-fails-create-instance-and-das) ### Other Issues |Error Code|Error Description|Resources| |---|---|---| |SQL30081N|Various TCP/IP communication errors. Each error has its own definition and action plan.|[SQL30081N TCP/IP communication errors](https://www.ibm.com/docs/en/db2/11.5?topic=errors-sql30081n-tcpip-communication)| |SQL1092N|“USERID does not have the authority to perform the requested command or operation”|[SQL1092N Error](https://www.ibm.com/docs/en/baw/19.x?topic=tic-db2-log-file-error-sql1092n-userid-does-not-have-authority-perform-requested-command-operation)| ## JDBC Drivers and Translators In some cases, you may need to add your own JDBC Driver, or configure a Translator. More information on configuring these can be found on the [JDBC Drivers and Translators](platform\database-connections\connecting-to-databases\jdbc-drivers-and-translators\jdbc-drivers-and-translators.md) page. However, you may need to check the JDBC driver's documentation for information on how to configure them.
