--- title: "AMI Access Instructions - AWS" --- # AMI Access Instructions - AWS > :::note Default Ports > Default ports for accessing the Ignition Cloud Gateway are located at ports `80` and `443`. > ::: ## Prerequisites Before launching your instance, you will need to configure the instance's network settings and add an inbound security group rule: 1. Under Network Settings, click **Edit**. 2. Verify that you are using the correct VPC and Subnet. 3. Enable **Auto-assign public IP**. 4. Select **Create security group**. 5. Click **Add security group rule**. 6. Set the Type to **HTTP**. This will expose port `80`, one of the default Gateway ports. 7. Configure the Source type to specify which IP addresses can access this port. ## Gateway Access Once you have configured and launched your instance, you can access and commission your new Gateway from the **EC2 Dashboard** > **Instances**: 1. Select the Ignition Cloud Edition instance. 2. Under the **Details** tab, locate the instance's **Public IPv4 address**. ![Gateway Access Step 2](gateway-access-step-2.png) 3. Copy the address. 4. In a new tab, paste the address and specify port `80`: ``` 54.245.215.77:80 ``` 5. Hit **Enter**. 6. When prompted, choose the username and password for your admin user. 7. Click **Finish Setup**. You will now be redirected to the [Cloud Edition Gateway](other-editions\ignition-cloud-edition\cloud-edition-gateway\cloud-edition-gateway.md). Now that you've accessed your Cloud Gateway, you can download the [Designer Launcher](launchers-and-workstation\designer-launcher\designer-launcher.md) and start working on projects. Follow the steps to [add a Designer](launchers-and-workstation\launchers-and-workstation.md) for your Cloud Gateway just like you would for any other edition of Ignition. ## Creating an EC2 Instance Using the Ignition Cloud Edition AMI ### Launch From AWS Marketplace 1. Go to the [AWS Marketplace](https://aws.amazon.com/marketplace) and search for **Ignition Cloud Edition**. 2. Select the [Ignition Cloud Edition AMI](https://aws.amazon.com/marketplace/pp/prodview-2rstgfnmrqc2o?sr=0-1&ref_=beagle&applicationId=AWSMPContessa). ![Launch from AWS Marketplace Step 2](launch-from-aws-marketplace-step-2.png) 3. Once on the Ignition Cloud Edition AMI product page, click on **Continue to Subscribe**. ![Launch from AWS Marketplace Step 3](launch-from-aws-marketplace-step-3.png) 4. You will be prompted to accept the terms of the EULA. Click **Accept Terms**. ![Launch from AWS Marketplace Step 4](launch-from-aws-marketplace-step-4.png) 5. After AWS has fulfilled your subscription request, click on **Continue to Configuration**. ![Launch from AWS Marketplace Step 5](launch-from-aws-marketplace-step-5.png) 6. You will have options to select the fulfillment option, version, and region to launch the software. In most cases, you won't need to change any settings. Make your selections, then click **Continue to Launch**. ![Launch from AWS Marketplace Step 6](launch-from-aws-marketplace-step-6.png) 7. On the "Launch this software" page, you can quickly set up many essential services your EC2 instance will need to function properly. In this example however, we will select **Launch through EC2** under the Choose Action dropdown, and then click **Launch**. ![Launch from AWS Marketplace Step 7](launch-from-aws-marketplace-step-7.png) :::note Although we can directly launch our Cloud Edition EC2 instance from this page, launching from the EC2 service will make it easier to set up other necessary elements, such as a VPC, subnet(s), and more. Additionally, the EC2 console contains other advanced settings you may be interested in configuring. ::: 8. You will be taken to your EC2 Service in a new tab, where you can fill out information about your new EC2 instance. Begin by giving your EC2 instance a name. ![Launch from AWS Marketplace Step 8](launch-from-aws-marketplace-step-8.png) :::note Since we started creating the EC2 instance from the AWS Marketplace, the **Application and OS Images** section will already be filled out. ::: 9. Select the Instance Type you want your EC2 instance to use. In this example, we are using the default selection of **m6i.xlarge**. ![Launch from AWS Marketplace Step 9](launch-from-aws-marketplace-step-9.png) 10. Select the key pair you want to use or create a new key pair. Alternatively, you can omit using a key pair, but for security purposes, this is not recommended. ![Launch from AWS Marketplace Step 10](launch-from-aws-marketplace-step-10.png) 11. Next, configure your network settings. For more information on configuring these settings, see the [Cloud Edition - AWS Networking and Security](other-editions\ignition-cloud-edition\ami-access-instructions-aws\cloud-edition-aws-networking-and-security\cloud-edition-aws-networking-and-security.md) page. 12. Choose the amount of storage you want for your Root volume and EBS volume(s). You can also add or remove volumes as needed. ![Launch from AWS Marketplace Step 12](launch-from-aws-marketplace-step-12.png) 13. You can set up additional advanced settings under **Advanced details**. Once you are done, go to the **Summary** section to get a quick glimpse at the new EC2 instance's configuration, then click **Launch instance**. ![Launch from AWS Marketplace Step 13](launch-from-aws-marketplace-step-13.png) 14. AWS will attempt to create your EC2 instance. Once complete, a green Success banner will show at the top of your page. To find your new EC2 instance, go back to the EC2 service in your AWS console, and click on **Instances**. ### Launch From EC2 Service 1. Go to the EC2 Service in your AWS Console. 2. Click on **Instances** under the Instances section. ![Launch From EC2 Service Step 2](launch-from-ec2-service-step-2.png) 3. Click on **Launch instances**. ![Launch From EC2 Service Step 3](launch-from-ec2-service-step-3.png) 4. You will be taken to a page to fill out information about your new EC2 instance. Start by choosing a name. ![Launch From EC2 Service Step 4](launch-from-ec2-service-step-4.png) 5. Next, you will need to select Inductive Automation's Cloud Edition AMI. In the Application and OS Images (Amazon Machine Image) section, click on **Browse more AMIs**. ![Launch From EC2 Service Step 5](launch-from-ec2-service-step-5.png) 6. To find the official IA Cloud Edition AMI, enter "Ignition Cloud Edition" in the search bar at the top. The AMI will be listed under **AWS Marketplace AMIs**. ![Launch From EC2 Service Step 6](launch-from-ec2-service-step-6.png) 7. Once you have located the Ignition Cloud Edition AMI, click **Select**, then **Continue**. ![Launch From EC2 Service Step 7](launch-from-ec2-service-step-7.png) 8. You will be brought back to the EC2 creation form. From here, select the Instance type you want to use. In this example, we will leave the default selection of **m6i.xlarge**. ![Launch From EC2 Service Step 8](launch-from-ec2-service-step-8.png) 9. Select the key pair you want to use. You can also create a new key pair, or not use a key pair at all. In our example, we will **Proceed without a key pair**. :::tip For security purposes, we recommend that you use a key pair when creating your EC2 instance. ::: ![Launch From EC2 Service Step 9](launch-from-ec2-service-step-9.png) 10. You will then need to configure your network settings. For more information on configuring these settings, see the [Cloud Edition - AWS Networking and Security](other-editions\ignition-cloud-edition\ami-access-instructions-aws\cloud-edition-aws-networking-and-security\cloud-edition-aws-networking-and-security.md) page. 11. Configure the amount of storage you want for your Root volume and EBS volume(s). You can also add or remove volumes. ![Launch From EC2 Service Step 11](launch-from-ec2-service-step-11.png) 12. Configure any advanced settings you'd like under **Advanced details**, then proceed to the **Summary** section. Once you are satisfied with the selections, click **Launch instance**. ![Launch From EC2 Service Step 12](launch-from-ec2-service-step-12.png) 13. AWS will now create your EC2 instance. Once complete, a green Success banner will show at the top of your page. To find your new EC2 instance, go back to the EC2 service in your AWS console, and click on **Instances**.
