--- title: "Parameterized Popup Windows" --- # Parameterized Popup Windows >
A parameterized popup window lets you pass parameters from one window into a popup window, where the receiving popup window could then use that parameter to display relevant information. This also allows you to maintain a single window that can be used to display similar information. For example, suppose you have two compressors: Compressor 1 and Compressor 2. Imagine clicking on one of the compressors on the main window and a popup displays the diagnostic information about that specific compressor. Instead of creating a popup window for each compressor, you can create a single popup and use indirection with the passed parameter to display a different compressor's information depending on which was selected. ## Passing Parameters to a Popup Window To pass parameters from one window to a popup window, the receiving popup window must have [custom properties](../../../working-with-vision-components/vision-component-customizer/vision-component-customizer.md) that receive the passed parameters. When the event on the parent window is called, the parameters are passed to the receiving Popup Window's custom properties on its root container. The component's properties on the receiving window can use the root container's custom properties to address their bindings. The following examples explain how to set up a popup window and main window to pass compressor numbers to the popup window in order to display relevant information about each compressor. ### Setting up the Popup Window 1. Right click on a folder in the Project Browser and select Popup Window to create a new popup. ![](step-1.png) 2. Drag a **Compressor** image from Symbol Factory. 3. Drag a **Label** component from the component palette to your window. ![](step-3.png) 4. Create a [custom property](../../../working-with-vision-components/vision-component-customizer/vision-component-customizer.md) on your popup window's root container that will receive the passed parameters. Right click on your window and select **Customizers > Custom Properties**. The Custom Properties window is displayed. 5. Click the **Add** ![](add.png) icon to add a property. 6. Specify a **Name** for the Custom Property, such as **compNum**, and click **OK**. ![](step-6.png) The custom property is created and displayed in blue at the bottom of the Property Editor. ![](step-6b.png) :::caution Do not bind these custom properties to anything, leave them unbound so you can pass values into them without any other values to override them. ::: 7. Let's use an expression on the Label to show what compressor number we are on. 1. Select the **Label** and click the binding ![](binding.png) icon for the **Text** property. 1. Select **Expression** for the binding type. 1. Click the **Insert Property Value** ![](insert-property.png) icon in the Expression window and choose the **compNum** custom property on the root container for the compressor popup window as shown in the image below. Click **OK**. ![](step-7.png) 8. Now, let's update the Expression using the script below to show the word "**Compressor**" before the number in the label. Update the Expression in the Property Binding field as follows: ```py title="Script to change the compressor number" "Compressor " + {Root Container.compNum} ``` 9. Click **OK** to save the property binding. ![](step-9.png) ### Setting up the Main Window 1. In a Main Window (parent window) drag a **Button** from the component palette to your window. Type "**Compressor 1**" into the text property. ![](main-window-step-1.png) 2. Let's add a script to the button which opens the popup that we created earlier. We can then pass in a value to designate that this button should be opening Compressor 1. 1. Right-click on the **Compressor 1** button and select **Scripting**. 1. Under Event Handlers, select **actionPerformed**. 1. Click the **Open / Swap** radio button. 1. Under Window, use the dropdown list to select the path to your Popup Window (i.e.,Popup_Param_Test). 1. Check the **Pass Parameters** check box, and click the **Add** ![](add.png) icon to add a parameter. 1. Click the new row under **Parameter Name** and a dropdown list will appear. Select the custom property **compNum**. :::note Ignition will automatically check the Root Container of the window selected in the **Window** dropdown. If you do not see the **compNum** parameter, it may have been created on wrong component, so check the Root Container of the Compressor Popup window. ::: 1. Enter "**1**" in the **Value** column because the button will be for Compressor 1. 1. Click **OK** to save the script. ![](main-window-step-2.png) 3. Now, create a second compressor button. A quick way to do this is duplicate (**Ctrl D**) the Compressor 1 button so it inherits the script. Update the Text property to **Compressor 2**. 4. Right-click on the new **Button** component and select **Scripting**. Update the parameter Value being passed in from a **1** to a **2**. 5. Click **OK** to save the script. ![](main-window-step-5.png) 6. Test it out by putting the Designer in **Preview Mode**. Click one of the Compressor buttons, then navigate back and click the other Compressor button. While these buttons are opening the same popup, they display different information because they are using the parameter that we passed in for indirection. In this example, we just used a label, but the parameters can be used in things like [indirect Tag bindings](../../../binding-types-in-vision/indirect-tag-bindings-in-vision/indirect-tag-bindings-in-vision.md) or scripts to pull in various Tag bindings. ![](main-window-step-6.png) ## Passing a UDT to a Popup In addition to the basic types, parameters can be a complex [UDT type](platform/tags/user-defined-types-udts/user-defined-types-udts.md). This works much the same as passing in basic values, where the popup window has a custom property on the root container, and a parameter is passed in when opening the window. The difference is that the custom property on the popup window needs to be a UDT that has been previously defined, and the value being passed in when opening the window needs to be an entire UDT instance. This gives the popup access to every Tag within the UDT, which can be useful when making popups that show all the details of a certain area which has a UDT. ![](passing-udt.png)
