--- title: "Setting Up Auto Login" --- # Setting Up Auto Login > 1. In Designer, go to **Project > Properties**. The **Project Properties** window is displayed. > 1. Scroll down to **Vision > Login.** > 1. Click the **Enable Auto-Login** checkbox. > 1. Enter a Username and Password. > 1. Click **OK**. ## Client Auto Login Clients can log in automatically when launched, once you specify the **Auto Login** settings in the **Client/Login** section of the [Project Properties](ignition-modules\vision\vision-project-properties\vision-project-properties.md) window. This is typically used in situations where the client should login with a low access user, such as a 'guest' account. ### Set the Clients to Automatically Login In this example, we will set the project properties to allow Ignition clients to automatically login. ![](setting-up-auto-login.png) 1. Select the **File > Save All** to save your changes to the Gateway and your project. ![](setting-up-auto-login-2.png) When in a client that has auto login set up, if the user accidentally logs out there is a button on the login screen to allow the user to enter in the auto login credentials. That way there is no need for them to know any login credentials. ![](setting-up-auto-login-3.png)
