--- title: "Dropdown List Example" --- # Dropdown List Example > Dropdown lists are used when you want to select a single item from a list of options. The Dropdown component is under the Input section of the component palette. Simply drag it on to your window. The most important property of a Dropdown component is the Data property. It is a Dataset that contains one or more rows of data. Each of the rows are different options that you see on the component. Select the Dropdown component and click on the **Dataset Viewer** ![" "](dropdown-list-example-dataset-viewer-icon.png) icon for the Data property to manually add some options. ![" "](dropdown-list-example-dataset-viewer.png) ## Data Property's Dataset Modes There are three modes you can use the **Data** property’s dataset: a number/label pair, a single label column, and a code/label pair. Which mode is used depends on what columns are in the **Data** property’s dataset, and will determine the values of the **Selected Value**, **Selected String Value** and **Selected Label** properties. Any additional columns that are added to the dataset will not affect these properties. ### Number/Label Pair In the Number/Label Pair mode, the first column of the Dataset is an integer (often an id) and the second column is a string (often a label). The first column is the **Value** column which is invisible to the user and is usually used in binding. The second column is the **Label** column and is visible to the user in the dropdown list. In this example, the dataset has two rows. The **Value** column includes the integers **1** and **2**. Under the **Label** column, **Realtime** and **Historical** are displayed, respectively. ![" "](dropdown-list-example-dataset-editor.png) In **Preview Mode**, select from the list of dropdown options. Notice, you can only see the options in the **Label** column. Select the **Realtime** option. Now, under the Data property section, the **Selected Value** is **1**, which is the corresponding integer in the Value column of the dataset. The **Selected String Value** and the **Selected Label** both display **Realtime**, which is the corresponding string in the Label column of the dataset. ![" "](dropdown-list-example-preview.png) ### Single Label Column The Single Label Column mode you can use is a string/string combination which are two columns that are both strings. 1. In the Dataset Editor, remove the **Value** column from our example by selecting a cell in that column and clicking on the Vertical Delete ![" "](dropdown-list-example-vertical-delete-icon.png) icon. 2. Add another column by clicking on the Vertical Add ![" "](dropdown-list-example-vertical-add-icon.png) icon. 3. Call the new column **'Code,'** set the column position to **'0'** and make it a **'String.'** Click **OK**. Both columns are now strings. ![" "](dropdown-list-example-dataset-editor-add-column.png) 4. Under the **'Code'** column enter **'v1'** and **'v2.'** Click **OK**. ![" "](dropdown-list-example-dataset-editor-code-column.png) :::note Because we added the 'Code' column in position '0,' the users will see the same two options in the dropdown list: 'Realtime' and 'Historical.' If you see 'v1' and 'v2' instead, that means your 'Code' column is not the first column. ::: 5. In Preview Mode, click on **'Historical'** and you can see the Selected String Value is **'v2'** because the value is in the first column and the Selected Label is **'Historical.'** ![" "](dropdown-list-example-preview-2.png) ### Code/Label Pair The Code/Label Pair mode simply uses a one string column. 1. In the Dataset Editor, remove the **Code** column from our example by selecting a cell in that column and clicking on the **Vertical Delete** ![" "](dropdown-list-example-vertical-delete-icon.png) icon. 2. You are going to see the same two options in the Dataset Viewer: **‘Realtime’ and ‘Historical.’** :::note This only applies if there is exactly one column in this dataset. ::: ![" "](dropdown-list-example-dataset-editor-column-removed.png) 3. In **Preview Mode**, select the **‘Realtime’** option. You will see the same value in the **Selected Label** and **Selected String Value** properties since there is only the one column. ![" "](dropdown-list-example-preview-3.png) ## Setting Dropdown Options Now, you can set these dropdown options manually or bind the Data property. In this example, you can take a Dropdown List on the window and bind the Data property using a SQL query. 1. Select the Dropdown component, and click on the **binding** ![" "](dropdown-list-example-binding-icon.png) icon for the Data property. 2. Select the **SQL Query Binding Type** and enter a query that brings back an ID and Name from one of your tables in the database. ![" "](dropdown-list-example-sql-binding.png) 3. Click **OK** to see all the options that came back from the database. 4. In Preview Mode, select any one of these options and you can see the **Selected Value**, **Selected String Value**, and **Selected Label** as shown in the following example. ![" "](dropdown-list-example-preview-4.png) ## Displaying Multiple Columns in a Downdown List Another feature of the Dropdown List component is you can show more than one column to a user. 1. Drag another Dropdown component to your window. 2. Go to the **Dataset Viewer** and add some options manually. Instead of having only one or two columns you can add as many as you want. The first column needs to be either an **integer** or a **string**. Any additional columns will show up in the dropdown. 1. Open the Dataset View, under **Value**, enter **‘1’** and **‘2.’** 2. Under **Label**, enter **‘Realtime’** and **‘Historical.’** 3. Add another column and call it **‘Col3’** in **'Position 2'** , and make it a **string** and click **Add Column**. 4. Under Col3, enter **‘This is real time’** and **‘This is historical'**. 5. Click **OK**. ![" "](dropdown-list-example-dataset-editor-col3.png) 3. In the Property Editor, set the **Dropdown Display Mode** to **‘Table’** to see both columns. ![" "](dropdown-list-example-table-mode.png) 4. Now you can see **Label** and **Col3** and select between those different rows. It’s a nice way to show more information in the Dropdown list. The **Selected Value**, **Selected String Value**, and **Selected Label** properties will behave the same as previous examples ignoring any columns beyond the second. ![" "](dropdown-list-example-final-result.png)
