--- title: "Getting Started with Report Charts" --- # Getting Started with Report Charts > Report charts offer many functions and features, including various chart types. The best chart type for you to use depends on your data and how you want to display it. This page uses a Timeseries Chart example to demonstrate the necessary steps for adding a chart to a report. ## Creating a Report Chart One of the most common charts used for historical trending is a [Timeseries Chart](appendix/components/report-design-components/report-design-chart-palette/report-component-timeseries-chart/report-component-timeseries-chart.md). The Timeseries Chart plots values against a timestamp X axis. Adding a chart to a report involves a few steps: 1. The chart needs data, so we must create a data source. 2. Once a data source exists, we can create the chart and assign the data source. 3. Apply any additional chart configuration, such as adding an additional axis. Now, let's follow these steps to create a Timeseries Chart using Tag History data. ### Creating a Data Source :::info Before you start this example... This procedure requires a device connection and a database connection. * Ignition comes with one internal Tag Provider you can use with the [Programmable Device Simulator](ignition-modules/opc-ua/opc-ua-drivers/programmable-device-simulator/programmable-device-simulator.md) as a starting point if your Gateway is not currently connected to a PLC. This example assumes your device is named 'generic' and you are using the Generic Program device tags, but any tags can be used. * The [database connection](platform/database-connections/connecting-to-databases/connecting-to-databases.md) is needed for the historian to store Historical Tag data. This example assumes [Tag History has been enabled](ignition-modules/tag-historian/configuring-tag-history/configuring-tag-history.md) on the **Sine** tags. ::: 1. In the **Data** tab, under Parameters and Data Sources, click the **Add** ![](plus-icon.png) icon to add a data source. Select **Tag Historian Query**. ![](datasource.png) 2. Under the **Available Historical Tags** column, open the folder structure until you locate your tags. As mentioned above, we are using the Programmable Device Simulator and loaded the Generic program. so we will select the 'generic' folder in this example. Here you'll find a bunch of tags you can use immediately. Expand the **Sine** folder. 3. Select a few of the tags (i.,e. sine0, sine1, sine2) and drag them to the **Selected Historical Tags** column under **Tag Path**. Take a look at the properties down at the bottom. Set the **Data Range** property to **Historical**, and the **Aggregation Mode** to **Time-weighted Average**. ![](data-tag-history-query.png) ### Adding a Chart Switch over to the **Design** panel now to add your chart. 1. Drag a **Timeseries chart** from the Report Design Palette into the report and expand the chart to fit the page. 2. From the **Key Browser**, expand the **Datasources** folder, and drag your datasource (i.e., tag_history) down to the **Data Key** under the **Chart Options tab** of the Property Inspector. The **Domain Key** is auto-filled in with the **t_stamp** column name. 3. Select **Test1** and **Test2** pens and delete them by selecting each pen individually and then clicking the **Trash** ![](trash-can-icon.png) icon. 4. Once the Data Key is correct, you can assign pens to your chart. Drag in your **Keys** (i.e., sine0, sine1, sine2) to the **Pens** property table. You'll immediately notice your chart is populated with fake data, this is just a preview and does not represent the data returned by your data source. ![](image2017-9-6_11-40-0.png) 5. You can modify a selected pen by clicking the Edit ![](edit-icon-1.png) icon or Preview column to open the **Edit Pen** tab. You can change the name of the pen, change the pen style, color, and more. Let's change the color of the pens, starting with the sine0 pen: * Set the **Color** to be red. * To return to the Chart Options tab, click the arrow ![](single-backwards-arrow-icon.png) button. * Repeat these steps for the remaining two pens, making sine1 green, and sine2 dark blue. ![](edit-style-color.png) 6. Go to the **Preview** tab to view the Timeseries Chart in the report. ![](image2017-9-6_12-13-39.png) ### Adding an Axis It's hard to see the small changes in our sine0 pen because its range is smaller than the other pens. Let's fix this by adding a new axis. 1. Return to the Design tab and select the chart. Click the **Add** ![](plus-icon.png) icon next to the Axes table to add a new axis, then click the **Edit** ![](edit-icon-1.png) icon below it to edit our new Axis. * Give it a name of **Sine 0 axis** * Give it a label of **Value for Sine0** * Change the position to right so that it displays on the right side of the chart. * We can leave **Auto Range** turned on, so that it will automatically pick the appropriate min and max for the sine0 pen. ![](edit-axis.png) 2. Return to the **Chart Options** tab by clicking the arrow ![](single-backwards-arrow-icon.png) button. 3. We now need to tell our sine0 pen to use that new axis. Select the sine0 pen from the pens list and click the **Edit** ![](edit-icon-1.png) button. 4. Change the Axis of the pen to one we just created. 4. Navigate to the **Preview** tab to view our finished chart. ![](image2017-9-6_14-0-49.png)
