--- title: "Perspective Component Methods" --- # Perspective Component Methods > A component method is a function that is defined on a component object. For example, this is how we would call a component method defined on the component object **self**: ```python output = self.myMethod(param1,param2) ``` Perspective has a variety of component methods that are defined on all components, and it also offers you the ability to configure your own using custom methods. ### Autocomplete A complete list of component methods (with their definitions) is available from the autocomplete popup. Starting in 8.1.18, the autocomplete popup is enabled by default and will appear after typing "." To disable this feature, right-click anywhere within the Script Editor window and deselect **Automatic Activation**.  ## Object Traversal In most Perspective scripts, you are given a reference to a component object (often in the form of a **self** parameter). The object is given in component scripts, but has several methods and properties associated with it to help traverse to the other objects in a Perspective View or get values from the Session. Object Traversal is limited to a single view. If a script needs to reference a component in a different view, or there is a possibility that the hierarchy of the view will change, then [Message Handling](ignition-modules\perspective\scripting-in-perspective\component-message-handlers.md) should be utilized instead. ### Component/Container | Method/Property | Description | Example | | ------------------- | -------------- | ---------- | | .children | Returns all of the component's children. |
self.children| | .getChildren() | Functionally similar to ".children" above. |
self.getChildren()| | .parent | Calling this property will move up the component hierarchy, accessing the parent container of the preceding object. Root containers will return the view, and views/sessions will return None. |
self.parent| | .getParent() | Functionally similar to ".parent" above. |
self.getParent()| | .getChild(string) | Method that looks for a child component of a given name. Returns None if not found.String can either be the name of a child object, or a path to an object delimited by a forward slash, allowing you to move through multiple items in the hierarchy in a single call. |
self.getChild('Label_0')self.getChild('Container/Label_0') |
| .getSibling(string) | Returns a reference to an object in the same container that the source component is located in. Similar to calling self.parent.getChild('component'). | self.getSibling('Label') |
| .view | Calling this from anywhere within a view will return the parent view of the object. | self.view| | .getView() | A method that will return the view, similar to ".view" above. |
self.getView()| | .page | Returns a page object associated with the page the current component is on..close() can be called on the page object, and can accept a message string as a parameter. |
page = self.pagepageID = page.props.pageIdpagePath = page.props.path| | .getPage() | A method that will return the page, similar to ".page" above. |
self.getPage()| | .session | Returns the current Perspective Session you are in. From this object you can get any of the existing properties of the Session, including custom properties. See the Session Objects sub table for more details. |
session = self.sessionsesName = session.props.gateway.addresssesProp = session.custom.propertyName| | .getSession() | A method that will return the session, similar to ".session" above. |
self.getSession()| ### Session Objects | Method/Property | Description | Example | | ---------- | ----------------------- | ----------- | | .close()or.close(message) | When called will close the session.Optionally accepts a string message which will be displayed after the session closes. |
session = self.getSession()session.close("The session has now closed") |
| .getInfo() | Returns a PyJsonObjectAdapter object, which is functionally similar to a Python Dictionary. The object contain the same keys described on the [system.perspective.getSessionInfo](appendix\scripting-functions\system-perspective\system-perspective-getSessionInfo.md) page. | self.session.getInfo()["pageIds"]| | .getPages() | Returns a list of page objects. |
self.session.getPages()| | .getPage(ID) | Returns the page associated with the given string ID parameter, if it exists. Page ID values can be determined with the .getInfo() method. |
self.session.getPage("2b2eb647") |
| .getProjectInfo() | Returns a dictionary of project meta data, including name, title, description, lastModified, lastModifiedBy, views, and pageConfigs. | self.session.getProjectInfo()| ### View Objects | Method/Property | Description | Example | | --------------- | ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- | ---------------------------------------------------------------------------------------------------- | | .rootContainer | Returns the root container of the View. |
view.rootContainer| | .id | Returns a string that uniquely identifies the view instance. For example:`Perspective/Views/path/to/view yields path/to/view@C` |
view.id| | .session | Returns the current Perspective Session you are in. From this object you can get any of the existing properties of the Session, including custom properties. See the Session Objects sub table for more details. |
session = view.sessionsesName = session.gateway.addresssesProp = session.custom.propertyName| ### Object Traversal Examples If you want to get other component properties in a view while scripting, you can use the above methods and properties to move around the View. These examples assume you have the following structure/components in a View: - View - Button 1 - Text Field 1 - Container 2 - Text Field 2 - Container 3 - Text Field 3 - Container 4 - Button 4 - Text Field 4 ```python title="Scripting Example: Get Component Properties from a Button Script" # this example code exists on the 'Button 1' in the above hierarchy. # get to the view that the button is in view = self.view # get the text from 'Text Field 1' text1 = self.getSibling('Text Field 1').props.text # get the text from 'Text Field 2' text2 = self.getSibling('Container 2').getChild('Text Field 2').props.text # get the text from 'Text Field 3' text3 = self.getSibling('Container 3').getChild('Text Field 3').props.text # get the text from 'Text Field 4'. Either of these will work the same. text4 = self.getSibling('Container 3').getChild('Container 4/Text Field 4').props.text text4 = self.getSibling('Container 3').getChild('Container 4').getChild('Text Field 4').props.text ``` ```python title="Scripting Example: Get Component Properties from a Button Script" # this example code exists on the 'Button 4' in the above hierarchy. # get to the view that the button is in view = self.view # get the text from 'Text Field 1' text1 = self.parent.parent.getSibling('Text Field 1').props.text # get the text from 'Text Field 2' text2 = self.parent.parent.getSibling('Container 2').getChild('Text Field 2').props.text # get the text from 'Text Field 3' text3 = self.parent.getSibling('Text Field 3').props.text # get the text from 'Text Field 4' text4 = self.getSibling('Text Field 4').props.text ``` ## Built-In Methods Perspective components contain several shared methods. This section details such methods. Some methods are only available to certain types of components. In these cases, the description for the method will state any limitations. ### Refreshing Bindings The `refreshBinding` function can be used to manually fire a binding, and is designed to be used on bindings that can poll (like query and Tag history bindings). In these instances, using refreshBinding in lieu of polling can save Gateway resources. The refreshBinding() function takes a string as a parameter, corresponding to the property that should be refreshed: ```python self.refreshBinding("props.data") ``` It is often useful to use refreshBinding() from a [component message handler](component-message-handlers.md), since we can then refresh several applicable bindings via a single [system.perspective.sendMessage](../../../appendix/scripting-functions/system-perspective/system-perspective-sendMessage.md) call. ### Requesting Focus The `focus` method can be called by a component to request focus in a view. This is useful if you wish to control where keyboard input is directed after a particular action. Due to the nature of focus, calling the focus method is only effective on components that can have focus. Input components such as the Text Field and Numeric Entry Field components can gain focus, but Display components like Labels and Images can not gain focus. ```python self.focus() ``` ### Requesting or Removing Tooltips The `requestTooltip` and `removeTooltip` methods can be used to display and remove tooltips from a scripting event. This is useful if you wish to allow users to request tooltips in a mobile session, where there is no `onMouseEnter` event. You may call these functions for any component with meta tooltips enabled. Requesting a tooltip will have no effect if tooltips are not enabled for the component. ```python self.requestTooltip() self.removeTooltip() # enable and then call tooltip for 'Label 1' in the same view self.getSibling('Label 1').meta.tooltip.enabled = True self.getSibling('Label 1').requestTooltip() ``` ### Requesting or Removing Context Menus The `requestContextMenu` and `removeContextMenu` methods can be used to show or hide the context menu from a scripting event. As with the `requestTooltip` and `removeTooltip` methods, these methods are helpful to users in mobile sessions, to view or hide configured context menus. Requesting or removing a context menu will have no effect if the component context menu is not configured. ```python self.requestContextMenu() self.removeContextMenu() ``` ### Requesting Print The requestPrint method can be called by a component, view, or page to print the contents of the selected target. If no target is specified, the component serves as the default target. Titles can also be assigned if saving the printed file. To request print using a Perspective component action instead, see the [Request Print Action](../working-with-perspective-components/component-events-and-actions.md#request-print-action) section on the Component Events and Action page. ```python self.requestPrint() self.requestPrint('component', 'MyTitle') ``` The following example demonstrates how to use the requestPrint method for the various expected targets of component, view, or page. If left blank, the default target will be component: ```python self.requestPrint(target='component', documentTitle='MyTitle') self.requestPrint(target='view', documentTitle='MyTitle') self.requestPrint(target='page', documentTitle='MyTitle') ``` The following example demonstrates how to invoke the requestPrint method on other components: ```python self.getSibling("ToggleSwitch").requestPrint(target='component', title='MySwitch') ``` ## Custom Methods Perspective offers the option of configuring your own methods for a component. To configure a custom method: 1. Right-click on the desired component in the Designer, and select **Configure Scripts...**. 2. Under **Custom Methods**, double click on ![](
