--- title: "Connecting to Kepware OPC UA" --- # Connecting to Kepware OPC UA > >
OPC UA makes connecting to third party OPC servers quick and easy without all the headaches associated with COM. This is a detailed step-by-step guide to connecting to KEPServerEX from Ignition using OPC UA. ## Connect to KEPServerEX from Ignition using OPC UA 1. In the **Config** section of the Gateway, go to **OPC Client** > **OPC Connections**. The OPC Connections page is displayed showing the OPC UA servers your Ignition is connected to. 2. Click on **Create new OPC Connection…**. 3. Choose **OPC UA** as the connection type, and click **Next**. 4. On the Server Discovery page,enter the endpoint of the OPC UA server Ignition should connect to. For example: | Sample Format | Localhost Example, Default Port | Remote Example, Custom Port | |---|---|---| | opc.tcp://IpAddress:Port | opc.tcp://localhost:49320 | opc.tcp://10.1.1.10:4444 | Click on the **Next** button to continue. ![Connect to KEPServerEX Step 4](connect-to-kepserverex-step-4.png) 5. Select the Server you want and click **Next**. ![Connect to KEPServerEX Step 5](connect-to-kepserverex-step-5.png) 6. A list of available Endpoints with Security Policies and Security Modes options appears. ![Connect to KEPServerEX Step 6](connect-to-kepserverex-step-6.png) Once an endpoint configuration has been selected, click the **Next** button. 7. On the Manage Certificate page select **Yes** for **Trust Certificate?** and click Next. :::note Using Redundancy Since Ignition does not automatically approve third party OPC UA server certificates, a backup Gateway will need the certificate approved manually for any created OPC UA connection. This can be done on the **Config** > **OPC UA** > **Security** page under the **Quarantined Certificates** section. ::: ![Connect to KEPServerEX Step 7](connect-to-kepserverex-step-7.png) 8. Confirm your settings and click **Finish**. ![Connect to KEPServerEX Step 8](connect-to-kepserverex-step-8.png) 9. This takes you to the new OPC Connection screen. Fill in the **Username** and **Password** if your KEPServer connection requires it. Most current installations of KEPServer require a login and will not connect without one. See the [No Anonymous Token Policy Found](#no-anonymous-token-policy-found) section below. ![Connect to KEPServerEX Step 9](connect-to-kepserverex-step-9.png) 10. Click **Create New OPC Connection**. 11. The connection will appear as **Faulted**. This is expected because KEPServerEX is denying access to the Ignition OPC UA Client. The next step is to have KEPServerEX trust the Ignition OPC UA Client. 12. On the computer that KEPServer is installed on, right-click on the **KEPServerEX** icon on the desktop KEPServerEx is installed on, and from the menu select **OPC UA Configuration**. The **OPC UA Configuration Manager** will appear. ![Connect to KEPServerEX Step 12](connect-to-kepserverex-step-12.png) 13. On the OPC UA Configuration Manager window, go to the **Trusted Clients** tab. 14. Click on **Ignition OPC UA Client**, click the **Trust** button, and click **Close**. Now the OPC Server Connections page shows the Status of Kepware to be Connected. ![Connect to KEPServerEX Step 14](connect-to-kepserverex-step-14.png) 15. Again, right-click on the **KEPServerEX** icon on the desktop KEPServerEx is installed on, and from the menu select **Reinitialize**. 16. Go back to the Ignition Gateway Webpage. In the **Config** section, go to the **OPC UA** > **Security** page. 17. Under the Client Security tab, you will find your new connection listed as Quarantined. Click on the **Trust** button on the far right. ![Connect to KEPServerEX Step 17](connect-to-kepserverex-step-17.png) 18. Go back to the **Config** section of the Gateway, to **OPC Connections** > **Servers**. The Status of your KEPServer connection should be **Connected**. 19. To test your tag connections, go to the **OPC Connections** > **Quick Client** in the Configure section of the Gateway. Expand the **KEPServer** object until you find tags. ### Troubleshooting If **Status** does not read **Connected**, click the **edit** link next to the server connection, scroll down to the bottom of the connection configuration page, and click **Save**. If **Status** is still reading something other than **Connected**, click the **OPC Connection Status** link at the bottom of the **OPC Server Connections** page and see if there are any useful messages to help troubleshoot the issue. Also, ensure your firewall is not blocking traffic on the port that KEPServerEX is using to communicate. ### Failover The failover Kepware OPC UA server works the same as the OPC UA server with the exception that you need to have two copies of Kepware set up, preferably on different servers. The failover Kepware OPC UA server will be used in the event the primary Kepware server goes down. To enable failover, check the box to **Show advanced properties** in the New OPC UA Connection Settings, set the **Failover Enabled** property to '**true**', and specify the **Failover Endpoint**. The **Backup** properties should be used when a pair of redundant Ignition Gateways are trying to look at the same Kepware OPC UA server. Both the **Backup Discovery URL** and **Backup Endpoint URL** properties need to be configured. For additional information on Failover, refer to [OPC UA Client Connection Settings](ignition-modules\opc-ua\opc-ua-client-connection-settings\opc-ua-client-connection-settings.md). ### No Anonymous Token Policy Found When connecting to KepServer, some versions may not allow anonymous connections by default. This typically means you need to specify user credentials for Ignition to use in the OPC UA server connection. Alternatively, individual Kepware Projects can allow anonymous login. For more information, look into allowing "anonymous login" in [KepServer's OPC UA Configuration Manager documentation](https://www.kepware.com/en-us/support/resource-library/). ## Other UA Servers While the above example is specific to KEPServerEX, the same concepts apply to connecting to any other third party OPC server that accepts OPC UA client connections. The only difference may be in the way that the certificates are accepted on the server. The Ignition OPC UA server sends the client certificate to the third party OPC server when it tries to make the connection, however if the OPC server is not designed to expect these certificates then there may not be a straight forward way to accept them. In these cases, you can manually download a client ticket from Ignition and supply it to the OPC server in the appropriate manner. ### Download a Client Certificate Manually 1. Go to **Config** section in the Gateway Webpage. 2. Select **OPC UA** > **Certificate** from the left side of the page. The Manage Certificates page is displayed. 3. In the **This Gateway** tab, click the download link under **Ignition OPC UA Client**, and save the certificate somewhere to disk. This certificate is then supplied to your third-party OPC server in a way specific to that server. For more information, check the respective server's documentation.
