--- title: "Connecting to CompactLogix" --- # Connecting to CompactLogix > :::note > This driver is made for CompactLogix firmware up to version 20.18. > ::: ## Connect to an Allen-Bradley CompactLogix Device 1. Go to the **Config** section of the Gateway Webpage. 2. Scroll down and select **OPC UA** > **Device Connections**. ![Connect to AB CompactLogix Step 2](connect-to-ab-compactlogix-step-2.png) 3. On the **Devices** page, find the blue arrow and click on **Create new Device**. 4. Select **Legacy Allen-Bradley CompactLogix**, and click **Next**. ![Connect to AB CompactLogix Step 4](connect-to-ab-compactlogix-step-4.png) 5. On the **New Device** page, leave all the default values and type in the following fields: * Name: **CompactLogix** * Hostname: type the **IP address** for the PLC, for example 10.20.4.55. ![Connect to AB CompactLogix Step 5](connect-to-ab-compactlogix-step-5.png) 6. Click **Create New Device**. The **Devices** page is displayed showing the **CompactLogix** device is added to Ignition. The **Status** will show as Disconnected and then Connected. ![Connect to AB CompactLogix Step 6](connect-to-ab-compactlogix-step-6.png) 7. To see all the Tags, go to **OPC Client** > **Quick Client** in the **Config** section. On the **OPC Quick Client** page, expand the **CompactLogix** folder and in the **Global** folder you can see all the tags. ## Device Connection Settings The **General** settings are common to all Allen Bradley devices, and the **Connectivity** settings are device dependent. ### General Settings | Name | Description | |:---|:---| | Name | The user-defined name for this Device. The Device Name must be alphanumeric. | | Description | The user-defined description for the device. This is only used as a note to differentiate between devices. | | Enable Device | Only devices that are enabled appear in **Connections** > **Devices** of the **Status** page of the Gateway and thus have their Tags available for use. Default is true. | ### Connectivity Settings | Name | Description | |:---|:---| | Hostname | This is the IP Address of the Ethernet module to route through to connect a CompactLogix processor. | | Local Address | The local address to connect from when establishing a TCP connection. If left blank, then the driver will simply pick an available address. | | Timeout | The timeout settings refer to the communication between the device driver and the OPC-UA server and usually can be left at their default values. | | Connection Path | The Connection Path value is used to define the route to connect to the processor. The Connection Path format contains 4 numbers separated by commas. The first number is always 1 and tells the Ethernet module to route through the backplane. The rest of the numbers vary by device type, for a more in depth explanation of connection paths, see [Allen Bradley Connection Paths Explained](ignition-modules\opc-ua\opc-ua-drivers\allen-bradley-ethernet\allen-bradley-ethernet.md#allen-bradley-connection-paths-explained) section. | | Concurrent Requests | The number of requests that Ignition will try to send to the device at the same time. Increasing this number can sometimes help with your request throughput, however increasing this too much can overwhelm the device and hurt communications with the device. | ### Advanced | Name | Description | |---|---| | Disable Automatic Browse | Disables the automatic browse setting. Default is false. | | Show String Arrays | Disables the Show String Arrays setting. Default is false. | | Status Request Poll Rate | Controls the poll rate for status requests, in milliseconds. Default is 1,000. |
