--- title: "Introducing Ignition" description: "Ignition SCADA by Inductive Automation® combines an unlimited licensing model with instant web-based deployment and the industry-leading toolset for supervisory control and data acquisition (SCADA)" --- # Introducing Ignition > Ignition SCADA by Inductive Automation® combines an unlimited licensing model with instant web-based deployment and the industry-leading toolset for supervisory control and data acquisition (SCADA) ## What is Ignition? Ignition by Inductive Automation® combines an unlimited licensing model with instant web-based deployment and the industry-leading toolset for supervisory control and data acquisition (SCADA), all on one open and scalable universal platform. Ignition is "The New SCADA" because it solves all the major pain points of old SCADA. Ignition empowers your business to easily control your processes to track, display, and analyze data, without limits. Ignition is designed to be approachable and easy to get started with, while being flexible and capable of scaling up to the largest projects. Ignition is unlimited; for the low cost of one server license, you can connect all your data, design any kind of industrial application, and instantly deploy web-based unlimited Clients and Sessions to anyone or anywhere, all from one universal platform. The features below are core to Ignition. | | | |:-:|:--------------------------------------------------------------------| |![](introducing-ignition-imgs/server-based.png)|**Server-Based**: One computer controls everything in Ignition. You install a server in one place and connect everything else to that server. With this feature, you can have as many [Client](ignition-modules\vision\vision-client-interface\vision-client-interface.md) runtimes, [Sessions](ignition-modules\perspective\perspective-sessions\perspective-sessions.md), and [Designers](platform\designer\designer.md) as you want.| |![](introducing-ignition-imgs/licensing.png)|**Simple Licensing**: Only one [license](platform\licensing-and-activation\licensing-and-activation.md) for your server is required. This gives you unlimited access to various features such as unlimited Clients, Sessions, [tags](platform\tags\tags.md), and [projects](platform\projects\projects.md). Without limits on these resources, you can exchange important data and analytics with your entire team, and across your whole company. Ignition allows you to create and use as many tags as you need for different purposes like [devices](ignition-modules\opc-ua\opc-ua-drivers\opc-ua-drivers.md), [OPC servers](ignition-modules\opc-ua\third-party-opc-servers\third-party-opc-servers.md), and runtimes. | |![](introducing-ignition-imgs/web-based.png)|**Web-Based Deployment**: Ignition is installed, deployed, and managed using standard web technologies. You can connect from any computer on the network to perform actions like managing settings, updating projects, creating new tags, and launching new runtimes. | |![](introducing-ignition-imgs/designer-clients.png)|**Designers, Clients, and Sessions**: You can download the [Designer Launcher](launchers-and-workstation\designer-launcher\designer-launcher.md) to make changes to your projects, the [Vision Client Launcher](launchers-and-workstation\vision-client-launcher\vision-client-launcher.md) to launch Clients, and [Perspective Workstation](launchers-and-workstation\perspective-workstation\perspective-workstation.md) to launch Sessions. Alternatively, you can create deep links for each type of launcher pointing towards specified projects. Any of these options can be set up on any system in your network, giving you and your users access to Ignition from anywhere your network extends. In initial benchmark testing, Ignition Perspective can simultaneously and easily launch 200 Sessions. | | ![](introducing-ignition-imgs/security.png)|**Built-in Security**: Security is built into every aspect of Ignition. You can [manage users](platform\security\classic-authentication-strategy\managing-users-and-roles\managing-users-and-roles.md), edit screen permissions at the individual [tag](platform\tags\tag-properties\tag-security-properties\tag-security-properties.md) or component level for both [Vision](ignition-modules\vision\security-in-vision\component-and-window-security\component-and-window-security.md) and [Perspective](ignition-modules\perspective\security-in-perspective.md), and even secure certain assets in your projects. | |![](introducing-ignition-imgs/modules.png)|**Scalable Modular Architecture**: You can create a scalable and centrally managed SCADA system using Ignition's web-based server architecture. Configure unlimited connections to PLCs, databases, and web-launched runtimes, along with web-based deployment, and different types of [System Architectures](system-architectures\system-architectures.md) to suit your needs. Projects can initially be created small and expanded out indefinitely as your business grows, or you can have smaller installations connected to and interacting with other larger systems.| |![](introducing-ignition-imgs/cross-platform.png)|**Cross-Platform**: Ignition is built on Java and runs on Windows, macOS, and Linux. Perspective Sessions can be accessed from browsers on iOS and Android devices. [Backups](platform\gateway\gateway-backup-and-restore\gateway-backup-and-restore.md) of your system are also cross-platform, allowing you to load a backup from any system. | ## New in This Release * Ignition 8 features a new poll-free protocol that updates tag data instantly for both Vision and Perspective clients. As a result, Vision clients in Ignition 8 are drastically faster while using dramatically less CPU power. * For the new Vision Module, we’ve created new native Vision client launchers for Windows, Mac, and Linux, so you can easily launch Vision clients on any major operating system without needing to install and update Java. * Ignition Vision is perfect for dedicated plant-floor displays and HMIs, while Ignition Perspective is perfect for mobile-first industrial applications. You can use them on their own or together to form the industry’s most powerful, cutting-edge visualization system. * Vision client screens will look even better in Ignition 8, thanks to a new design and new support for high-resolution displays. * Fonts have also been improved with more choices and better rendering so your screens look sharper than ever. * Ignition 8 has an improved concurrent editing system which allows multiple people to work on the same project at the same time without locking each other out of resources. This will help your team work faster and more collaboratively. * In Ignition Perspective, you can use powerful and flexible CSS3 styles to change the appearance and position of anything in your application. By combining styles into themes, you'll be able to apply and edit styles across multiple applications in an instant. For a full list of new features, see the [New in this Version](new-in-this-version\new-in-this-version.mdx) page. ![](features.png) ## What Can Ignition Do? Because of its modular nature, Ignition can be customized to your needs. A lot of the basic functionality is shared between modules and stored in the Gateway to make everything smooth and seamless. Some of these basic functionalities include database connections, device connections, tags, security profiles, and alarming. Because these are all shared resources, you don't have to manage multiple connections for the different modules in Ignition. Ignition's modular platform also supports your requirements by allowing you to select the modules you need and build processes suited for your business. You do not need to pay for any modules you do not want. Using Ignition, you can build projects like [database](platform/sql-in-ignition/sql-in-ignition.md) applications, point of sale (POS) systems, customer relationship management (CRM) tools, and inventory tracking software. Additionally, you can bring in data from any SQL database in your plant and interact with other existing enterprise resource planning (ERP) software and Access systems. See the sections below to learn more about how Ignition utilizes all of these available tools for some inspiration of what's possible. ### Web-Based HMI and SCADA Applications Deployment Using web technologies, you can access programmable logic controllers (PLCs) and connect to SQL databases on any platform. Ignition provides common HMI/SCADA capabilities easily and efficiently by allowing you to: * Create Clients and Sessions that show current or past data * Interact with your other systems and devices * Create displays and controls for anything wired into your system * See and manage your entire system from one place ![](introducing-ignition-imgs/hmi-design.png) ### High-Performance Historian You can use any SQL database with Ignition’s [Tag Historian](ignition-modules\tag-historian\tag-historian.md) module. In addition to being simple to set up, Ignition will record and manage the data for you. The historian includes partitioning and uses compression algorithms for fast data storage and retrieval. ![](introducing-ignition-imgs/historian.png) ### Reporting Engine You can [create dynamic PDF reports](ignition-modules/reporting/reporting.md) that users can see and change anytime. This can be automated by creating a schedule during which documents such as analytical data or compliance reports can be generated or emailed out. Your users can change date ranges on any reports you create or select past reports without any changes to the system. ![](introducing-ignition-imgs/reports.png) ### Alarming You can use Ignition’s alarming engine to [create alarms](platform/alarming/alarming.md) for any conditions. Alarms can be shelved, recorded, acknowledged, or handled through notifications and messaging. Email, standard text messages (SMS), and voice messages can be sent to individuals or lists of users based on any logic you need. ![](introducing-ignition-imgs/alarming.png) ### Communications Hub You can use Ignition as an effective communication hub in your network. You can use some or all of these features to make Ignition move data back and forth throughout your facility. Connect everything together with: * OPC-based communication to interact with almost [any OPC server](ignition-modules/opc-ua/third-party-opc-servers/third-party-opc-servers.md) * [SQL-based](platform/database-connections/database-connections.md) JDBC drivers to connect to any number of databases * Built-in [PLC drivers](ignition-modules/opc-ua/opc-ua.md) to connect to any PLC (such as Allen-Bradley, Siemens, Modbus) through OPC * Web services to support launching anywhere * System compatibility with [other enterprise systems](platform/database-connections/database-connections.md) (ERP) * [Connections to devices](ignition-modules/opc-ua/opc-ua-drivers/udp-and-tcp-driver/udp-and-tcp-driver.md), such as barcode scanners, scales, and sensors * Connections to any mobile device, such as wireless smartphones and tablets * Connections to any touch panel screen or human machine interface (HMI) ![](introducing-ignition-imgs/hub.png) ### Design Projects and Resources By using different components and linking them to tags, each other, and different parts of your project, you can create any type of application you need. You can also directly interact with any projects you create or modify in the Designer as if you were an operator using the Designer's Preview Mode. This helps users test their projects before deploying any changes across your architecture. Using the features available in Ignition, you can create projects such as the one pictured below. ![](introducing-ignition-imgs/mix-match.png) ## Understanding Ignition’s Flow Ignition is easy to install and straightforward to use, from project creation to production deployment and beyond. Once Ignition is installed, follow the steps below to set up and launch a project: * **Launch the Gateway Webpage**: The Gateway Webpage is where you store all of your information, and configure all of your general settings, like device connections, database connections, security, Gateway backups, and redundancy. * **Launch the Designer**: Once your connections are in place, you can use them when developing a project. Download the Designer Launcher or set up a deep link on any system that can connect to your Gateway, and then launch the Designer to begin creating your project. Add resources such as tags, query databases, status metrics, history trends, and alarms to your project. * **Save your Project**: When you save, Ignition sends all your data and changes back to the Gateway. Everything is centrally stored in the Gateway, so you never have to worry about managing several versions or trying to combine multiple changes into one. You can even launch Designers concurrently to allow multiple people to work on the same project at the same time. Projects are not limited in scope, allowing you to create them for anything you can think of, such as HMIs, general SCADA software, reporting, history, and alarming. * **Launch Client and Session Runtimes**: You can launch one runtime or multiple at the same time. Download the Vision Client Launcher, Perspective Workstation, or create a deep link on any system within your network to launch Clients and Sessions the same way as the Designer. All of your runtimes talk directly to the Gateway to get new information, eliminating any worry about sync issues or individual runtime loading changes. ![](introducing-ignition-imgs/ignition_flow.png)
