--- title: "system.util.translate" description: "This function allows you to retrieve the global translation of a term from the translation database using the current locale." --- # system.util.translate > This function allows you to retrieve the global translation of a term from the translation database using the current locale. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax :::tip This function accepts [keyword arguments](../../../platform/scripting/python-scripting/user-defined-functions.md#keyword-arguments). ::: `system.util.translate(term, [locale], [strict])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `term` | The term to look up. String| `locale` | Which locale to translate against. Useful when there are multiple locales defined for a single term. If omitted, the function attempts to use the current locale (as defined by the client, session, or Designer). [optional] Boolean| `strict` | If false, the function will return the passed term (param 1) if it could not find a defined translation for the locale: meaning, if you pass a term that hasn't been configured, the function will just send the term back to you. If true, then the function will return a None when it fails to find a defined translation. Default is false. [optional] ### Returns **String** - The translated term. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # This script will take a term written into a Text Field component, translate it using the translation database, # and then write it back to the same Text Field. # it uses the current locale since none is specified. text = event.source.parent.getComponent('Text Field').text translation = system.util.translate(text) event.source.parent.getComponent('Text Field').text = translation ``` ```python title="Example #2" # This code block demonstrates how to use the locale parameter. # Use the currently detected locale. system.util.translate("Hello") # Translate to Italian. system.util.translate("Hello", "it") # Translate to a regional variant - Irish English in this case. system.util.translate("Hello", "en-ie") ```
