--- title: "system.util.queryAuditLog" description: "Queries an audit profile for audit history." --- # system.util.queryAuditLog > Queries an audit profile for audit history. This function is used in **Python Scripting**. ## Description Queries an audit profile for audit history. Returns the results as a dataset. A description of the returned dataset can be found on the [Ignition Database Table Reference](../../reference-pages/ignition-database-table-reference/ignition-database-table-reference.md#audit-log) page. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax - Gateway Scope `system.util.queryAuditLog(auditProfileName, [startDate], [endDate], [actorFilter], [actionFilter], [targetFilter], [valueFilter], [systemFilter], [contextFilter])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `auditProfileName` | The name of the audit profile to pull the history from. Date| `startDate` | The earliest audit event to return. If omitted, the current time - 8 hours will be used. [optional] Date| `endDate` | The latest audit event to return. If omitted, the current time will be used. [optional] String| `actorFilter` | A filter string used to restrict the results by actor. [optional] String| `actionFilter` | A filter string used to restrict the results by action. [optional] String| `targetFilter` | A filter string used to restrict the results by target. [optional] String| `valueFilter` | A filter string used to restrict the results by value. [optional] String| `systemFilter` | A filter string used to restrict the results by system. [optional] Integer| `contextFilter` | A bitmask used to restrict the results by context. 0x01 = Gateway, 0x02 = Designer, 0x04 = Client. [optional] ### Returns **Dataset** - A dataset with the audit events from the specified profile that match the filter arguments. ### Scope Gateway ## Syntax - Perspective Session and Vision Client Scope `system.util.queryAuditLog([auditProfileName], [startDate], [endDate], [actorFilter], [actionFilter], [targetFilter], [valueFilter], [systemFilter], [contextFilter])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `auditProfileName` | The name of the audit profile to pull the history from. [optional] **Note:** The project must have an Audit Profile configured in Project Properties. Otherwise this parameter is mandatory. Date| `startDate` | The earliest audit event to return. If omitted, the current time - 8 hours will be used. [optional] Date| `endDate` | The latest audit event to return. If omitted, the current time will be used. [optional] String| `actorFilter` | A filter string used to restrict the results by actor. [optional] String| `actionFilter` | A filter string used to restrict the results by action. [optional] String| `targetFilter` | A filter string used to restrict the results by target. [optional] String| `valueFilter` | A filter string used to restrict the results by value. [optional] String| `systemFilter` | A filter string used to restrict the results by system. [optional] Integer| `contextFilter` | A bitmask used to restrict the results by context. 0x01 = Gateway, 0x02 = Designer, 0x04 = Client. [optional] ### Returns **Dataset** - A dataset with the audit events from the specified profile that match the filter arguments. ### Scope Perspective Session, Vision Client ## Code Examples ```python title="Example #1" # This script queries an audit log, checks to see if a user john made any tag writes in the last 8 hours # (since the startDate parameter is omitted), and writes the results to a table. data = system.util.queryAuditLog(auditProfileName='AuditLog', actorFilter='john', actionFilter='tag write') event.source.parent.getComponent("Table").data = data ```
