--- title: "system.util.getGatewayStatus" description: "Returns a string that indicates the status of the Gateway." --- # system.util.getGatewayStatus > Returns a string that indicates the status of the Gateway. This function is used in **Python Scripting**. ## Description Returns a string that indicates the status of a Gateway. A status of `RUNNING` means the Gateway is fully functional. If an exception occurs, the function returns `ERROR` with the associated error message appended. This function can be used to test the availability and operational state of a remote Gateway. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.util.getGatewayStatus(gatewayAddress, [connectTimeoutMillis], [socketTimeoutMillis])` ### Parameters | Type | Parameter | Description | | ------- | ------- | ------ | | String | `gatewayAddress` | The Gateway address to ping, in the form of ADDR:PORT. | | Integer | `connectTimeoutMillis` | The maximum time in milliseconds to attempt to initially contact a Gateway. [optional] | | Integer | `socketTimeoutMillis` | The maximum time in milliseconds to wait for a response from a Gateway after initial connection has been established. [optional] | | Boolean | `bypassCertValidation` | If the target address is an HTTPS address, and this parameter is True, the system will bypass all SSL certificate validation. This is not recommended, though is sometimes necessary for self-signed certificates. | ### Returns **String** - A string that indicates the status of the Gateway. A status of RUNNING means that the Gateway is fully functional. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" REMOTE_GATEWAY = "10.20.6.253:8088" def check_remote_gateway(address=REMOTE_GATEWAY): try: status = system.util.getGatewayStatus(address) except Exception as err: print "Error checking Gateway status for {0}: {1}".format(address, err) return if status == "RUNNING": print "Central Gateway is available!" else: print "Central Gateway status: {0}".format(status) # Run asynchronously so the call doesn't block the calling thread (UI/gateway event thread). system.util.invokeAsynchronous(check_remote_gateway) ```
