--- title: "system.util.getConnectionMode" description: "Retrieves this client session's current connection mode." --- # system.util.getConnectionMode > Retrieves this client session's current connection mode. This function is used in **Python Scripting**. ## Description Retrieves this client session's current connection mode. 3 is read/write, 2 is read-only, and 1 is disconnected. ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.util.getConnectionMode()` ### Parameters Nothing ### Returns **Integer** - The current connection mode for the client. ### Scope Vision Client ## Code Examples ```python title="Example #1" # This code will set a client to read-only after a timeout of 30 seconds. # Add this code to a client timer script mode = system.util.getConnectionMode() if mode == 3 and system.util.getInactivitySeconds() > 30: system.util.setConnectionMode(2) ```
