--- title: "system.util.audit" description: "Inserts a record into an audit profile." --- # system.util.audit > Inserts a record into an audit profile. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.util.audit([action], [actionTarget], [actionValue], [auditProfile], [actor], [actorHost], [originatingSystem], [eventTimestamp], [originatingContext], [statusCode])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `action` | What happened. Default is null. [optional] String| `actionTarget` | What the action happened to. Default is null. [optional] String| `actionValue` | The value of the action. Default is no value. [optional] String| `auditProfile` | Where the audit record should be stored. Defaults to the project’s audit profile (if specified), or the Gateway audit profile if calling in the Gateway or Perspective Session scope. [optional] String| `actor` | Who made the change. Will be populated automatically if omitted, assuming there is a known user. [optional] String| `actorHost` | The hostname of whoever made the change. Will be populated automatically if omitted. [optional] List[String]| `originatingSystem` | An even-length list providing additional context to the audit event. Will be appended to the automatically generated list. Typically, the automatically generated context looks like this: ```sys:${gatewayName}:\project:${projectName}``` If you provided `[“component”, “Joe’sButton”, “field”, “value”]`, you would get a record with: ```originatingSystem:sys:${gatewayName}:\project:${projectName}:``` ```\component:Joe’sButton:\field:value.``` If a string is provided, this automatic context will not be used and your provided string will be written directly into the originatingSystem column in the audit profile. [optional] | Date| `eventTimestamp` | When the event happened. Will be set to the current time if omitted. [optional] Integer| `originatingContext` | What scope the event originated from: 1 means Gateway, 2 means Designer, 4 means Client. Will be set automatically if omitted. [optional] Integer| `statusCode` | A quality code to attach to the object. Defaults to 0, indicating no special meaning. [optional] ### Returns Nothing ### Scope Gateway, Vision Client, and Perspective Session. ## Code Examples ```python title="Example #1" # All of the parameters are optional, so you're free to only provide parameters you're interested in. # In the very least provide just the action you wish to record, which gives the function a chance to look up all of the other parameters automatically. system.util.audit("The user did a thing!") ``` ```python title="Example #2" # Simple example just showing parameter usage. myAction = "The button was pressed" myTarget = "My Button" system.util.audit(action = myAction , actionTarget = myTarget ) ```
