--- title: "system.user.isUserScheduled" description: "Will check if a specified User is scheduled currently or on a specified date/time." --- # system.user.isUserScheduled > Will check if a specified User is scheduled currently or on a specified date/time. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions This scripting function has no [Client Permission](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties) restrictions. ## Syntax `system.user.isUserScheduled(user, [date])` ### Parameters Type | Parameter | Description ------- | ------- | ------ User| `user` | The user object to check the schedule for. Date / Integer| `date` | The date to check schedules for. May be a Java Date or Unix Time in ms. If omitted, the current date and time will be used. [optional] ### Returns **Boolean** - True if the user is scheduled for the specified date; false if not. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # Print whether or not the user "oper1" is scheduled currently. user = system.user.getUser("", "oper1") if system.user.isUserScheduled(user): print "oper1 is scheduled" else: print "oper1 is not scheduled" ```
