--- title: "system.user.createScheduleAdjustment" description: "Creates a schedule adjustment." --- # system.user.createScheduleAdjustment > Creates a schedule adjustment. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](ignition-modules\vision\vision-project-properties\vision-project-properties.md#vision-permissions-properties): User Management Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.user.createScheduleAdjustment(startDate, endDate, isAvailable, note)` ### Parameters |Type | Parameter | Description | |------- | ------- | ------| |Date| `startDate` | The starting date of the schedule adjustment.| |Date| `endDate` | The ending date of the schedule adjustment.| |Boolean| `isAvailable` | True if the user is available during this schedule adjustment.| |String| `note` | A note about the schedule adjustment.| ### Returns **Schedule Adjustment** - A [ScheduleAdjustment](https://sdk.inductiveautomation.com/javadoc/ignition81/latest/com/inductiveautomation/ignition/common/user/schedule/ScheduleAdjustment.html) object that can be added to a user. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1" # Specify the range of the schedule change. start = system.date.parse("2019-07-01 17:00:00") end = system.date.parse("2019-07-05 17:00:00") # Create an adjusted schedule. scheduleAdjustment = system.user.createScheduleAdjustment(start, end, True, "Summer swing schedule change.") # Get the user we need to adjust. user = system.user.getUser("default", "george") # Apply the adjusted schedule to the temporary user that lives in this script. user.addScheduleAdjustments([scheduleAdjustment]) # Override the old george user in the user source, with the new user we created in this script. system.user.editUser("default", user) ```
