--- title: "system.tag.rename" description: "Renames a single tag or folder." --- # system.tag.rename > Renames a single tag or folder. This function is used in **Python Scripting**. ## Description ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): Tag Editing Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.tag.rename(tag, newName, [collisionPolicy])` ### Parameters Type | Parameter | Description ------- | ------- | ------ String| `tag` | A path to the tag or folder to rename. String| `newName` | The new name for the tag or folder. String| `collisionPolicy` | The action to take when a tag or folder with the same path and name is encountered. Defaults to Abort. [optional]. Possible values include:a - Abort and throw an exceptiono - Overwrite and replace existing tag's configurationi - Ignore that item in the list. ### Returns **QualityCode** - A QualityCode object that contains the results of the rename operation. ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1 - Rename a Folder" old = "[default]folder/tag" new = "noun_1" # Note that the new name should not include the full path or tag provider. Just the name suffices. system.tag.rename(old, new) ```
