--- title: "system.tag.deleteTags" description: "Deletes multiple tags or tag folders." --- # system.tag.deleteTags > Deletes multiple tags or tag folders. This function is used in **Python Scripting**. ## Description Deletes multiple tags or tag folders. When deleting a tag folder, all tags under the folder are also deleted. ## Client Permission Restrictions [Permission Type](../../../ignition-modules/vision/vision-project-properties/vision-project-properties.md#vision-permissions-properties): Tag Editing Client access to this scripting function is blocked to users that do not meet the role/zone requirements for the above permission type. This function is unaffected when run in the Gateway scope. ## Syntax `system.tag.deleteTags(tagPaths)` ### Parameters Type | Parameter | Description ------- | ------- | ------ List | `tagPaths` | A List of the paths to the tags or tag folders that are to be removed. ### Returns **List** - A List of QualityCode objects, one for each tag in the list, that is representative of the result of the operation. See [Scripting Object Reference](appendix\reference-pages\scripting-object-reference\scripting-object-reference.md#qualitycode). ### Scope Gateway, Vision Client, Perspective Session ## Code Examples ```python title="Example #1 - Deleting Tags" # This example will delete several Tags. Modify the paths argument to change which Tags will be deleted. # Note that a confirmation isn't automatically included, so be cautious when calling this on a production server. paths = [ '[default]A_Tag', '[default]Folder/Some_Other_Tag' ] # Delete the Tags. results = system.tag.deleteTags(paths) # We could expand this example further by examining the list of quality codes... for index in range(len(results)): # ...check if a returned anything except Good. if results[index].isNotGood(): # ...and do something if we failed, such as retrieve the Tag path from earlier, and pair it with a quality code. print 'Could not delete tag at path: %s \n Reason: %s' % (paths[index], results[index]) ```
